| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
Hi guys, I am completely new to the CNC thing. Hope you can help me out with a problem I am having? Just recently purchased a 6040 router/mill from an ebay seller. It came with a HY01D523B VFD & a GDZ-65-800 water cooled spindle. I got the table up and running with no issues. But when running Mach3 (in demo mode), as soon as I start spindle rotation, the external EStop command is triggered. I tried changing the debounce setting in Mach3 from 0 to up to 10000, but all that meant was it took longer for the fault to occur (obviously it is a constant signal). The spindle supply cable is not shielded (as supplied), so I thought it may be introducing noise into the system. So I removed the cable from the cable snake and ran it separately, but same issue. Then rans a separate ground cable from the spindle mount to the VFD. Still the same result. If I remove the spindle from the machine, I can run it with no issues (spindle running), I can also lay the cable all over the other cables with no issue.But as soon as I touch the casing of the spindle to the machine, the external e-stop is triggered. There is no connection between the VFD and the breakout box (ie no spindle control other than the VFD). This is the machine I got: CNC 6040 ROUTER ENGRAVER DRILLING / MILLING MACHINE c6 | eBay The VFD is different to the one pictured, but everything else is the same. Ideas guys please? I am stuck with a non-functioning machine at the moment (a very expensive paperweight). Last edited by Tony344; 04-16-2011 at 03:32 AM. Reason: thought of some more info.. |
| Also did another test with the spindle out of the machine. There was a potential of 60V AC between the table and the spindle on powerup of the VFD and at full RPM the potential difference was 150V AC (both measured with a multimeter). I opened the control box (contains the stepper control cards and the parallel port interface + a Power Supply), and the incoming earth wire has been disconnected (so the control box is not internally grounded). Looks like I am going to have to go on a serious grounding exercise... Would it pay to place a ground wire to the parallel port interface card? (see pic below). Or am I likely to blow it? |
| Sounds like you definitely have grounding and bonding issues, the machine frame and the spindle motor frame should be bonded to earth ground. Your PC power supply is normally also connected to earth ground via the PC MB. I suspect the reading you are getting are stray leakage paths and will show on a high impedance meter. In place of the meter, place a load across the points you are measuring such as a 120/240v lamp etc, this will show if it is due to a path that will sustain current, if it does not and the voltage measured collapses then bond all these points to ground. This confirms whether or not anything will blow when you ground the various points out. It sounds to me like the machine itself is not bonded? Also double check your PC Parallel port common to ground to confirm you PC P.S. is grounded. Al.
| Pretty sure I am all sorted. Thanks for your input Al.. I appreciate it. I ran an earth from the spindle mount to the VF Drive. VF drive was earthed to incoming power. Also from VF Drive earth to Control box Earth. Earthed the non-earthed power supply in the control box + added an earth to the noise filter on the incoming supply for the control box. Seems stable and steady now. I have done a couple of test cuts with no issues so far. YouTube - DSCN0895.MOV |
| I just got the same machine mate, how you getting on with it
I'm looking at the same unit and I also noticed they are using a plastic/metal pannelled box, so the components are insulated from each other and nothing is earthed. Further, they have actually cut the earth lug off the input filter to the switchmode PSU. To my mind the parallel port shell or casing should be mains earthed, along with the VFD earth, the Spindle casing, the CNC frame, and the switchmode PSU of course? I can see a problem though with the 3 drive controllers that might need to be at digital ground, not mains earth. I recall some talk a while back about some drivers and/or interface controller card not being able to be at earth ground or it blew them? So i'm wondering if all the above mains earthing is the proper way to go and is done, but the drivers are lifted off the panel and insulated washers used if this is necessary? It's really nicely wired up, but poorly wiring implimented with ground and noise! I see you've got your's working but i'm worried about the mains earthing feedback long term to the drives, unless the chips are actually insulated on the heatsinks? cheers, Ian |
| IMO, many of the problems with noise are ground and bonded related, it is most unusual where a drive has switching devices that are common to chassis or signal ground. The majority of PC.s, at least tower or desk top have the M.B. ground plane at earth ground via the PC P.S. common. For optimum operation all Earth ground and bonding conductors should go to a central start point that has the system Earth ground conductor connected to it. Al.
#11
| did my first 3D design/cutting today. Nothing complicated, just proving concepts. Found the z axis drive connection was a little loose and caused some unwanted slippage early on (rectified). Seems repetitive movement will cause em to slip if they are going to slip at all.. |
#12
Hi, Just been reading up about the 6040's on ebay. (Seller industry-village) Aside from the earthing and loose axis, how is it going? It's seems good value for money, and I'm trying to decide on buy / build for a new router.. Cheers, Chris H. |
| Help with Huanyang HY02D223B | stevespo | Phase Converters and VFD | 248 | 03-15-2012 06:16 PM |
| Need Help!- Help Help Help - Huanyang VFd and spindle | PsychoPig7 | Phase Converters and VFD | 7 | 12-04-2011 09:19 AM |
| Huanyang VFD HAL Component | scotta | LinuxCNC (formerly EMC2) | 1 | 08-31-2011 10:53 AM |
| Problem- Huanyang HY02D223B goes POP! | stevespo | Phase Converters and VFD | 1 | 09-26-2009 02:12 PM |
| Need Help!- Huanyang HY02D223B 2.2Kw VFD | gillyhyde8888 | Phase Converters and VFD | 7 | 09-11-2009 06:46 PM |
