| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
There seem to be some Huanyang VFDs with a "speed dial" potentiometer on the little removable control panel, and others without. Mine came without but had the markings of its scale on the panle decal. I opened it up and sure enough, the panel is actually dirlled behind the adhesive decal AND it has all connections and holes for one on the PCB. I would REALLY like someone to unscrew the back of theirs WITH dial and tell me the resistance value (or codes) on the potentiometer PLEASE ![]() Thanks! Joe
__________________ Joe in Aus |
| Normally VFD speed pots will operate anywhere between 5k and 10k, make sure you get a Linear not logarithmic type. Al.
| Thanks Al. I am aware from the VFD manual that the EXTERNAL pot should be 10k, but the pot I'm asking about is in effect INTERNAL. I guess I should just get one and try it - I can always unsolder it again ![]() Joe
| OK, I did it! Took a little while to get a 10k linear potentiometer that fitted the holes and mounting points on the PCB inside the little control panel. It works nicely - although a little mysteriously: Firstly, I had to acutate it by setting the jumpers next to the external connector strips to 'Potentiometer on "kneading board" ' - that's what the manual calls the "Touch panel". Next, I had to set Pd002 (the source for frequency control) to 1 "external" - go figure. Then I had to experiment with Pd072 and Pd073 to set the starting and end frequencies for the potentiometer - opposite to what the manual says. Lastly, while Pd073 is actually "obeyed" to start the potentiometer, Pd072 is not. I ended up setting it to 250.00 (Hz) to get a full pot deflection of an indicated 140Hz. But that's all OK. It works nicely! Thanks for the help. Joe
| Agiepuls 30 control panel help | beadude | EDM Machines | 0 | 02-03-2010 11:48 PM |
| Lathe control panel | frogeye | General Metal Working Machines | 0 | 11-27-2008 07:31 AM |
| Control Panel Cut out | scruffyjones48 | Employment Opportunity | 5 | 08-03-2008 03:47 PM |
| T32 Control Panel Lock up | bean79au | Mazak, Mitsubishi, Mazatrol | 0 | 07-13-2008 04:59 AM |
| My DIY control panel | DennisCNC | CNCzone Club House | 6 | 10-02-2006 10:24 PM |
