Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 03-02-2011, 02:56 PM
Vegabond's Avatar
Vegabond is on a distinguished road
Red face Setting up and controll the vfd in mach3 why?
Hello, i have a friend here and help me to wire up some of the cnc stuff...
When we try to turn on/off the vfd trough mach3 it does not work.
we put the files in the plugin folder, but on the plugin tab on the top of mach3 is just the "video window" tab....
Can someone tell me what i do wrong?
Greetings from Robert.
My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
Old 03-02-2011, 03:49 PM
Bubba's Avatar
Bubba is on a distinguished road
In addition to the Mach setup, you most likely have to change some "Function" settings in the VFD
Art
Old 03-02-2011, 04:27 PM
Al_The_Man's Avatar
The VFD requires the analogue signal converted from the PWM in Mach and also the FWD or RUN command input to be turned on, which are you missing?
Or are both occurring but the VFD does not respond, if so it may be due to what Bubba alluded to.
Old 03-02-2011, 05:33 PM
ger21's Avatar
Sounds like your plugin is not installed. If it has an .mp3 extension, then double clicking should install it. Restarting Mach3 should have it listed.
I'm assuming this is the plugin for the Chinese VFD?
Old 03-05-2011, 04:06 PM
Vegabond's Avatar
yeah, it is the chineese one.
Here is the file i download ---> extract ---> mach3 "PlugIns" folder
Get nothing more in the plugin control tab in mach3.....
Greetins from Robert.
Old 03-05-2011, 06:00 PM
ger21's Avatar
Did you double click the plugin file to install it?
Old 03-06-2011, 04:34 AM
Vegabond's Avatar
No, i just put them in the folder...
Sorry, i forget to paste the link here it is http://www.machsupport.com/forum/ind...0;attach=20001
What do i need to do ?
Old 03-06-2011, 02:21 PM
Vegabond's Avatar
I have not wired like this picture ( http://www.cnczone.com/forums/attach...6&d=1256629138 ) but i have the wires from rs+ to A and from rs- to B..... try both but it didn`t work.
I think the problem is that i can`t get the drivers in the mach3... Do someone have some other plugin files for me ?
Old 03-07-2011, 03:35 PM
Vegabond's Avatar
I get up the huanyang plugin in the plugin control meny, but the PD001 and PD002 is value 99 instead for 2. Same com port, same vfd adress. The vfd has PD001 and PD002 value 2.
But it still don`t work.
The two wires from Rs+/rs- to A/B, if i use a multimeter, should some of the wires been in contact when the power is on?
Some tip?
Old 07-12-2011, 08:56 AM
Vegabond's Avatar
Hello agian....
Out of nowhere the spindel just would not work.
When i go to huanyang vfd in the plugin controll, i see the pd001 and pd002 has value 99 instead of 2... Last time it wouldnt work because the chip inside of the vfd was not assembled correctly...
Some tip?
I need a little help setting up Mastercam X4 with Mach3 8ABagel Post Processors for MC 6 02-19-2012 05:12 PM
Things not to do when setting up Mach3 ! Larken Viper Servo drives 3 12-04-2010 03:41 PM
Setting up Mach3 + CNC4PC BOB + VSD-A-r2 ftec Granite Devices 6 10-13-2009 06:04 PM
Basic Q's / Setting up Mach3 Thorpydo Mach Mill 3 09-24-2008 07:25 PM
setting 0,0,0 in Mach3 Mill sdantonio Mach Mill 33 04-01-2007 12:30 PM
