Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 02-27-2011, 02:45 PM
elohim1 is on a distinguished road
phase perfect 30 convertor sufficient for a Mazak QT 20 ?
I hope it is ! But I may be cutting it close afte some more research.
I have recently aquired a Qt20 with a T-2 control. It has a 20hp spindle motor . I also have aquired a phase perfect DPC-30 (30HP.) phase convertor and was wandering if this is going to be sufficient for the machine ? The phase convertor can produce like 90 amps @ 230 volts 3 phase.
Thanks in advance.
Old 02-27-2011, 04:56 PM
mactec54 is on a distinguished road
elohim1
How many amps are on the machine spec plate, you should have enough I think your PhasePerfect is good for 94Amps
& you most likely only need about 64 amps at 240v
Mactec54
Old 02-27-2011, 07:45 PM
Its a late 80's machine and there is no tag on it. The newer mazaks we have at work have electrical
Tags. The one i run is a SQT 30m. It is 30hp with milling capabilities. It says 126 amps @208.
Old 02-27-2011, 08:02 PM
scudzuki is on a distinguished road
Phase Perfect recommends the PP unit rating matching the spindle motor rating is sufficient. I run a 10 HP Cincinnati Arrow off a 10 HP Phase Perfect. The PP 30 will be plenty for your 20 HP spindle machine and most likely a 20 HP PP would be enough. Phase Perfects are awesome.
Joe
Old 02-27-2011, 08:06 PM
Joe,
That is good news !!!
Chris
Old 08-30-2011, 09:03 PM
ca434sbc4 is on a distinguished road
feedback on PP conveter
I also am looking at a phase perfect converter. So after 4+ months are you happy with it?
Thanks in advance.
Old 09-05-2011, 08:02 PM
I've never heard from a PP user who is dissatisfied on any of the forums.
Mine is still chugging along.
Joe
Old 09-05-2011, 11:05 PM
30Hp phase perfect convertor large enough for a Qt20 ? elohim1 Mazak, Mitsubishi, Mazatrol 0 02-27-2011 02:37 PM
How much is a phase 3 convertor? squale Phase Converters and VFD 7 11-20-2007 06:49 PM
How much is a phase 3 convertor? squale General Metal Working Machines 1 11-09-2007 11:30 AM
What to look for in a phase convertor? CNC Pro General Electronics Discussion 1 10-27-2003 09:40 AM
