Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 01-29-2011, 07:16 PM
AK_Five-O is on a distinguished road
VFD Selection
I am planning on using this motor with a VFD to run a Taig ER16 spindle. They also offer it in a 3/4 and 1/2 HP version as the 1HP may be overkill for the spindle.
Surplus Center - 1 HP 1725 RPM 208-230/460 VAC 3PH MOTOR
I was looking at the TECO JNEV-101-H1 with 120VAC 60HZ input.
1HP 115 Volt -- USE AS A PHASE CONVERTER PLUS GET VARIABLE SPEED, Model JNEV-101-H1, Single Phase Input ONLY, Three Phase Output, variable frequency drive, variable frequency drives, ac drive, vfd, afd, frequency drive, drive, inverter, adjustable sp
I'm on a budget but I'm a firm believer in "you get what you pay for". Is this a quality part or should I look at something else?
Bit selection Joe Weldor DIY-CNC Router Table Machines 1 12-07-2010 10:42 AM
Need help with saw selection thedave General Metal Working Machines 3 11-19-2010 11:44 AM
Please help with VFD selection HereinCS DIY-CNC Router Table Machines 40 08-03-2010 12:52 AM
Newbie- TM6 vs TM8 selection Help Kludge HURCO 4 06-11-2008 08:31 AM
Bit selection HB Adams WoodWorking 1 06-19-2006 05:32 PM
