Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 12-24-2010, 02:19 AM
Syphonics is on a distinguished road
Converting a 3 ph motor to 1 ph
Hi guys as above.
I have an old 420v 3 phase motor rated 4.2A 2200W lying around. As my power supply currently is only 1 ph, I would like to convert the 3 ph motor to run using only 1ph.
I have seen before some 3 ph motor coupled with a hugh capacitor to run the 3 ph motor using 1 ph power supply.
How do I calculate the capacitor rating?
I have a 12uf 450VAC capacitor is it sufficent?
And how do I actually connect them?
Is my circuit correct?
THanks
Old 12-24-2010, 03:52 AM
jeffrey001 is on a distinguished road
Cap should be around 70uF for each HP
Should give you about 2/3 of the actual motor HP rating.
But if you can afford it, sell the motor and get a single phase motor, lot easier.
Just my tough
Jeff
Old 12-24-2010, 02:34 PM
mike_Kilroy is on a distinguished road
you have 420v 1ph available? wierd voltage.... even tho you can do stuff like this, you still need nameplate voltage and freq for the motor to work.... is this a 50hz motor? you can't just stick a different voltage on it....
Old 12-24-2010, 02:41 PM
Al_The_Man's Avatar
A similar principle to a rotary convertor, you may want to tune it with caps to each phase to improve the power factor, as is done in a RPC.
AC Motor run rated capacitors are a must.
A RPC will 1 phase at first and blow the fuse/breaker if no way of starting the rotor to move is not carried out.
Check out the RPC files here http://metalworking.com/dropbox/_1998_retired_files/
With FRWx suffix.
Old 12-24-2010, 07:50 PM
oh the 3 phase motor is rated 420V 50Hz
Instead of purchasing an inverter to power this 420v 3 phase motor, I intent to use a capacitor as in my attached drawing. But I did not know what size of capacitor is needed for such a motor.
Old 12-25-2010, 09:39 AM
Al_The_Man's Avatar
An induction motor must when started obtain run speed within a second or two. If not it can overload fuses or breaker as I mentioned previously.
Normally to do it with a Capacitor, you require both a start and run cap.
The start cap is usually up to 10x and up larger than the run cap.
This must only be in circuit for the period of that the motor obtains run speed and immediately disconnected and the run cap is left in circuit at this point.
The start capacitor can be motor start rated as it is only in circuit briefly.
Various Capacitors values for both start and run have to be experimented with to obtain the optimum values while taking current readings.
Converting to +/-10v Possible? simonrafferty Gecko Drives 6 04-07-2010 08:30 AM
New Machine Build- Converting X1 iflymyhelishigh Benchtop Machines 1 12-22-2008 08:23 PM
Converting to 3 ph with a VFD reabdet21 General Metal Working Machines 6 07-17-2007 09:28 AM
Converting an Ordinary DC Motor to a Servomotor icanseco Servo Motors and Drives 1 11-01-2005 02:31 PM
converting to dfx qsacracer G-Code Programing 31 04-26-2005 03:43 PM
