Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 11-25-2010, 12:48 AM
jlmccuan is on a distinguished road
220 Single Phase thru VFD to 10HP 3 Phase
As the title says, I need to run a 3 phase 10 HP 220V electric motor with my 200A 220 single phase service. I also need speed control. Of course, always cheaply, if possible. Can any VFD with the correct rating be used for phase conversion? My application would draw litte amperage at slower speeds and would always be ramped up slowly. It is a blower without much weight, so the main load develops as the speed reaches max rpm.
Old 11-25-2010, 01:12 AM
diyengineer's Avatar
diyengineer is on a distinguished road
I'm guessing you will need a rotary phase converter. Not cheap to buy, but if your crafty you can make your own but probably not cheap cause you have a 10HP larger motor.
I'm stuck in your same boat exactly except i have a 5HP 3 phase motor i need to run.. On a budget.
Old 11-25-2010, 01:49 AM
I'm only running 2 HP now on single phase, but I need to go to at least 5. I figure if I set up for 10, I'm safe as I can't imagine ever needing this rig to require over 10HP. If it's really a big jump in cost and effort, I can back off on the HP requirement.
Old 11-25-2010, 02:14 AM
G5843 Static Phase Converter - 3 to 7 HP
Cheapest solution ive found yet. Notice you get 70% continuous HP and 90% intermittent HP for the first 15 minutes. Cant really beat that for $220 bucks.. I have a big 5HP motor i may try it out on..
For the price it would work well.
Old 11-25-2010, 02:20 AM
I have to have variable speed, too. The ad says for use with motors without digital controls, so how can I vary speeds?
Old 11-25-2010, 02:38 AM
Karl_T's Avatar
Karl_T is on a distinguished road
I use a 10 hp VFD off single phase on my lathe, no problem.
The first VFD I bought had phase sensor detection and wouldn't run on one phase so I had to trade it in.
Karl
Old 11-25-2010, 02:51 AM
Could you give more details on your setup?
Old 11-25-2010, 06:50 AM
Karl_T's Avatar
A lathe is just a bit more involved than a blower. For your application, L1 and L2 from your electric service. T1,T2, T3 to your motor. Personally, I'd use a small switch placed conveniently for on/off an put the VFD in a panel someplace. The VFD can then be programmed to turn on based on the switch and ramp up to speed.
Karl
Old 11-25-2010, 07:46 AM
So, pretty much any VFD rated above my motor could be used connected like this to control speed as well as convert from singe to three phase?
Old 11-25-2010, 08:18 AM
Karl_T's Avatar
yep, just stay away from the high end ones that are likely to have phase loss detection.
You don't need to oversize for what you're doing, just get a 10 horse VFD. But undersize won't work.
Karl
  #11   Ban this user!
Old 11-25-2010, 08:35 AM
Originally Posted by Karl_T View Post
....You don't need to oversize for what you're doing, just get a 10 horse VFD. But undersize won't work.
Karl
Read the specs carefully. You need a VFD that can accept single phase input and output 10 hp. You may have to get one that is rated something like 15hp when running from a three phase input because they are normall derated on a single phase suply.
  #12   Ban this user!
Old 11-25-2010, 08:43 AM
mactec54 is on a distinguished road
jlmccuan
There is a company that is making a 220/240 single phase to 220/240 3 phase for 10Hp, they would do the job for you just fine
Here is a link to 15Hp but they make a 10Hp
http://cgi.ebay.com/15-HP-PHASE-CONV...item20b5666d30
Mactec54
Convert three phase transformer to single phase? jimjovan General Electronics Discussion 3 12-10-2009 02:17 PM
fitting a 110v or 220v single phase spindle motor on a 3 phase machine mwood3 Benchtop Machines 12 10-12-2009 09:53 PM
Can I convert single phase motor to three phase? Jim Estes Phase Converters and VFD 30 01-24-2009 02:41 AM
3 phase transformer - on single phase? zcases General Electronics Discussion 3 10-21-2005 10:22 AM
3 phase transformer on single phase? jevs General Electronics Discussion 4 03-19-2005 11:25 AM
