Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 10-03-2010, 05:29 PM
waleed alhadidi is on a distinguished road
Can't run my spindle motor properly with the VFD
I have a chinese spindle motor with the following characteristics:
2.2kW 3phase 220V 400Hz 8.5A
And I bought a hyundai 2.2kW VFD and I've programed it with the motor parameters.
Now when I disconnect the motor the VFD gives me 400Hz, but when I connect the motor the inverter gives 3Hz at it's maximum and the motor rotates very slowly. I tried autotuning but nothing changed.
The question is: is there any information other than the above data I should know about the motor to program it to the VFD?
Stepper motor as a spindle motor Arich0908 Benchtop Machines 29 04-12-2010 12:39 PM
spindle motor and spindle control dont work customcncparts Milltronics 0 10-01-2009 02:08 PM
a paper shredder motor for spindle motor?? .xXACEXx. DIY-CNC Router Table Machines 4 06-02-2008 09:17 PM
Servo motor used as spindle motor? fatal-exception General Metal Working Machines 6 09-14-2007 02:55 AM
more rpms for spindle motor and spindle bob1112 Mechanical Calculations/Engineering Design 33 02-10-2007 01:01 PM
