Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 09-29-2010, 05:21 AM
SHORVATH is on a distinguished road
Need Help/Advice on VFD
I'm looking for some help/advice on a VFD to power a spindle I recently purchased of e-bay. The specs are as follows:
Air Bearings Ltd. AW125E/04
20 -125k RPM
3 Phase 200v Max 300 Watts
0 - 100v 0 667Hz 100 - 200v 667hz - 2048Hz
There are plenty of 1/2HP units units out there but most have
frequency 0 - 400Hz or 0 - 600Hz Max. Also the output voltage is
usually higher than 200v.
I have 120 and 240 single phase in my shop. Any recommendations?
Old 10-13-2010, 01:41 PM
Response from the Spindle Manufacturer:
Control Techniques have said today that the SP0203 drive should be satisfactory with the PWM set for 16KHz, although It is likely that the motor will run hotter than normal. I think that the SP0203 might be less expensive than Sieb & Meyer FC80
General advice and equipment advice GeorgiaRaised85 General Metal Working Machines 6 03-28-2010 05:00 AM
Looking for Advice duewy CNC Plasma and Waterjet Machines 3 09-27-2009 10:37 PM
Need some advice surfer13 CNC Wire Foam Cutter Machines 7 02-28-2008 10:52 PM
I need advice donmorris Milltronics 3 10-31-2007 09:01 PM
New and in need of some advice... well alot of advice! GoonShoes Bridgeport and Hardinge Mills 9 05-30-2007 07:03 AM
