| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
I have recently purchased a cnc mill that came with a Mitsubishi Freqrol-A024 Variable frequency drive (2.2 KW output) to control the 3 horsepower 3 phase spindle motor. Now i know that most VFD's can be run on single phase power and that it will output around 2/3 the total rated power of the motor but i'm wondering if there are any potential problems with running it on single phase instead of 3 phase. Basically im wondering if: 1.) will ANY vfd will run on single phase or is there a chance i will blow it up? 2.) would i be better off running the vfd from a surplus 3-phase motor that tacks on the 3 leg of power - even if i didn't balance the phase and voltage outputs (ie: if i made a rotary phase converter with a pull cord and a normal motor and then just ran this straight into my VFD). Would this be better or possibly worse without the voltage and phase being regulated? Thanks. |
| I'm running botha monarch 10EE and an Excello CNC nmill on VFD with single phase. No problems. I was told that the derating isn't even necessary in the smaller drives. My 10EE is a 5 hp VFD and a 5 hp spindle. Karl |
| Most VFD have plenty of protection in them, some (vary rare) need three phases to run, All the mitsubishi I have used you can run on single phase up to around 5hp. Most have a preference on the input terminals for the single phase input, on mitsubishi it is R S of RST terminals. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| encoder issues | rutexus | Servo Drives | 13 | 05-21-2006 07:49 PM |
| Rutex Servo issues. | ty1295 | Servo Drives | 3 | 05-28-2005 12:10 AM |
| Drive issues already!!! | ty1295 | Servo Drives | 12 | 09-02-2004 08:49 PM |
| Soft Wear Issues | bean7795 | General CAM Discussion | 1 | 04-15-2004 11:09 PM |
| ACAD 2002 issues???? | DanFri | Autodesk Software (Autocad, Inventor etc) | 4 | 07-02-2003 02:16 PM |
