| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
I recently got a CNC mill (Dyna Myte 4400). It cam with a rotary phase converter. It is an "anderson converters" 10 hp not their CNC version. The converter outputs 110 / 110 / 220 (two 110 legs and 1 220 leg). What is the difference between a CNC phase converter and a non CNC converter? Would a CNC converter have all three legs at 110v? Could I use this converter with this machine? If so how do I tell which lug to hook the "wild leg" to? What are the chances the previous owner toasted this machine using this converter? Any help or advice would be appreciated. |
| Are you sure it is not 220 input, if you mean by 110/110 means you are referencing to neutral, that is not used in a phase convertor. I have never heard of or seen a 110/110/240v 3 phase?? Al.
| 110 / 110 in 110/110/220 out. This is referencing ground. Open leg delta, high leg, wild leg, are some terms that I am researching tonight. |
| "low end" HF Spindle or "high end" router for about $1000? | biomed_eng | DIY-CNC Router Table Machines | 14 | 01-06-2012 12:15 AM |
| How to "offset" Double sided PCB if I don't have abolute "home" on my CNC ? | Calico | PCB milling | 11 | 07-12-2011 06:02 AM |
| Need Help!- "motor steps per resolution" and "driver microstepping" settings | margni74 | LinuxCNC (formerly EMC2) | 9 | 10-24-2009 02:33 AM |
| "J" head type "millport"(tiwan,1980) clutch | marksbug | Bridgeport and Hardinge Mills | 1 | 08-17-2009 10:48 AM |
| G320 "common" or "+5vdc" why do they vary? | beezerlm | Gecko Drives | 3 | 01-12-2008 04:00 PM |
