Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 08-25-2010, 09:19 AM
15mgtar is on a distinguished road
HITACHI 800Hz?
do HITACHI VFD run up to 800 Hz?
Old 08-25-2010, 09:29 AM
Al_The_Man's Avatar
The majority are 400hz, you need a specialized one for 800hz.
And also a 4 pole motor that is capable of 24000 rpm.
Old 08-25-2010, 11:08 AM
I am planning to get a 10HP 7.5Kw 24000RPM either 2 or 4 poles spindle motor from either colombo, fimec, or hsd to run @24000RPM I need 800Hz capable vfd. just wondering if the SJ series from Hitachi are capable going upto 800Hz.
Old 08-25-2010, 11:48 AM
Al_The_Man's Avatar
Not according to the specs, you should be able to look up a particular model spec online.
Old 08-26-2010, 12:42 AM
got it Thank you Al
oh btw is 4 poles motor better than a 2 poles motor (given all the specs are the same except the number of poles)?
Old 08-26-2010, 10:07 AM
Al_The_Man's Avatar
Rated torque or HP is rated at the base speed of the motor, so it depends at what rpm point you want your optimum torque to be.
Old 08-26-2010, 07:09 PM
So it doesn't matter wether it is 2 or 4 poles? on the 4 poles model speed is 12kRPM/24kRPM 400Hz/800Hz and the optimum torque is at 12kRPM above that the torque drops (I prefer the optimum torque around 18KRPM for wood)
Old 08-26-2010, 07:46 PM
Al_The_Man's Avatar
There is a trade off or balancing act as a 4 pole motor usually has more torque per HP than its 2 pole counterpart.
You would really need the performance figures at given rpm's for each to make a really concise selection.
Old 08-27-2010, 01:39 PM
Thank you Al.
This next question is off the topic: which is better HSD or FIMEC? or are they about the same?
hitachi etien4 Phase Converters and VFD 0 02-28-2010 11:58 AM
looking for hitachi help cnc_class Fanuc 3 01-20-2009 07:10 AM
Hitachi VFD ? QSIMDO Phase Converters and VFD 13 12-03-2008 11:24 AM
Hitachi 6M Spinner Plasma, EDM and other similar machine Project Log 0 07-06-2007 01:21 PM
Mach Driver test => Max 23,800Hz haysys Mach Software (ArtSoft software) 3 12-18-2005 01:12 PM
