Results 1 to 3 of 3
Thread: Siemens G110
    Dec 2009
    UK
    Siemens G110
    I have just bought a Siemens G110 with operator panel, unfortunately the panel is incorrect and I am waiting for the replacement.
    I want to use this vfd with my 2.2kw chinese spindle, and to control it using mach 3.
    In my green capacity I would appreciate a little guidance, what do I need to do to allow me to control the spindle speed from within mach3.
    do I need to purchase a spindle board or a siemens pc communication kit.
    Appreciate any help, this is a replacement for a chinese vfd that died.
    Dec 2009
    UK
    I've now got the correct op panel, and set all the basic parameters.
    Now the embarassing question - how do I actually change the speed using the op panel, its set to min 100Hz and max 400Hz, but when I start the spindle it only runs at 100 and doesn't appear to be changeable.
    Would appreciate a heads up on this one, or it's going to limit my cutting ability LOL
    Dec 2009
    UK
    Ok, well I solved the problem, so i'll pop it here for future searchers.
    P1000 default is 2
    frequency setpoint = analog setting
    I changed it be be driven by the op panel
    P1000 = 1
    Now I can use the up/down to change spindle speed.
  1. Need Help!- siemens 810 t
    By canrog in forum Post Processor Files
    Last Post: 07-02-2010, 08:43 PM
  2. Hidden values for Work Offsets (G110,111,112), Haas VF0
    By YendorZenitram in forum Haas Mills
    Last Post: 06-30-2010, 07:15 PM
  3. Siemens 810 T
    By promehanik in forum EMCO Lathe
    Last Post: 05-24-2010, 05:50 AM
  4. Siemens NX Cam
    By kurt5 in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 06-29-2009, 03:33 PM
  5. Siemens 850
    By Thunder in forum G-Code Programing
    Last Post: 09-17-2007, 04:10 PM
