| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
| What kind of motor? 1 phase? 3 phase? DC? If just a regular 1 phase induction motor, power it up and see what happens? What makes you think it needs checking? Al.
| How many leads and are they marked in any way. What does the name plate say? 220/440 dual voltage? Al.
so this is what I gather from the motor name plate HP: 7.5 RPM: 1725 VOLTS: 230/460 AMPS :22/15 PH: 3 HZ:60 also I open the motor splice box and it has 9 wires. the way the are connected goes like this 4and7 5and8 6and9 1is by itself 2is by itself 3is by itself. my question is still can I plug this in my home garage and how can I do it. thanks for all the help. |
| It looks like it is a dual voltage star connection in both speeds. You cannot check it on a regular domestic 1 phase supply, unless a phase converter or a variable frequency drive is used. Al.
| thanks for the info really appreciated. I am not quiet sure on what you mean but bassicaly what your saying is I need a phase converter and a variable frequency drive to check it. please bare with me I am not a electrician I just want to know what I need so when I do call a electrician he does not try to bulls_ _ t me around. any ways thanks for the help if you have any more suddjestion please let me . all I really whant to do is put the machine in the garage and put a variable frequency drive and make it run. thanks |
One or the other, both the phase convertor or the VFD will produce 3 phase from 1 phase. With VFD you get variable speed. Al.
| I would prefer a VFD know that you know my motor nameplate I am going to get a VFD. can you give some pointers on what kind I should buy also where , I have thought about EBAY. but I dont know what I should look for. thanks again |
#10
| That is a fairly large motor for 1 phase input, look for around a 10hp that will accept 1 phase at 220/240 input. Some here have bought the Toshiba or Fuji. I have picked up Mitsubishi, WEG, or Telemecanique off ebay. If getting second hand, make sure it has the program pad otherwise you would have to purchase separately. Al.
| Need Help!- Check if my Circuit is right.PIC18F4550- USB, Stepper Motor, keypad & SD-Card.. | Samuel Onesimus | PicStep Controllers | 7 | 12-14-2010 07:45 AM |
| motor shaft true-ness check | dsc | Calibration & Measurement | 2 | 01-26-2010 04:02 PM |
| Need Help!- 435 Runaway :Check motor wiring | electromech31 | AjaxCNC Control Products | 4 | 09-12-2009 12:15 AM |
| Check Carriage Sensor or VC Motor | jstovall | Printing, Scanners, Vinyl cutting and Plotters | 1 | 10-16-2006 07:52 PM |
| How do you check/test/measure step motor torque ? | Calico | Stepper Motors and Drives | 5 | 05-09-2005 05:51 PM |
