Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 06-02-2010, 07:11 AM
Me2 Me2 is offline
Me2 is on a distinguished road
Change a motor from 415v 3 phase to 220v 3 phase
I don’t know how I will go here but hopefully someone may have an answer. I have a good quality bench grinder specs are 1 HP, 415V 3 phase, 2800 RPM, 1.5 Amps.
Can this unit be run directly off 220V 3 phase without damaging it?
If not can it be converted from 415V to 220V, noting that there are only 3 wires coming out of the motor casing, if it can only be run at 415V in this configuration is it possible to make a change internally to allow rewiring to 220V? If so I would pass it to specialist motor rewinder to do this.
Cam
Old 06-02-2010, 09:23 AM
Al_The_Man's Avatar
Normally dual voltage motors have at least 3 pairs of wires coming off the motor, if dual voltage Star, then there would be a 9 wires.
If you only have 3 then I would suspect it has been wound for uniquely 415v.
If so opening it up would be no advantage.
Old 06-02-2010, 04:23 PM
Me2 Me2 is offline
Thanks for your reply Al, the other question, can it be run at the 230V 3 phase without damaging it?
Regards
Cam
Old 06-02-2010, 04:29 PM
Al_The_Man's Avatar
Not something I would recommend, the current induced into the rotor is going to be proportionately less this will lead to reduced torque, greater slip (rpm), etc, and will not take to load lightly.
If you try it, monitor the phase currents while you do.
I suspect the performance will be less than stellar.
Convert three phase transformer to single phase? jimjovan General Electronics Discussion 3 12-10-2009 02:17 PM
fitting a 110v or 220v single phase spindle motor on a 3 phase machine mwood3 Benchtop Machines 12 10-12-2009 09:53 PM
Can I convert single phase motor to three phase? Jim Estes Phase Converters and VFD 30 01-24-2009 02:41 AM
Just IN- CONVERT SINGLE 240/480V POWER TO THREE PHASE 415V OUTPUT PhaseChangeConv Product Announcements & Manufacturer News 0 09-02-2008 11:45 PM
2.5 amps per phase drive - 2.8 amps per phase bipolar motor ... kochevnik Stepper Motors and Drives 6 10-22-2006 10:48 PM
