Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 05-05-2010, 09:35 AM
JRoque is on a distinguished road
Hitachi SJ300 RS-485
Hello,
I have a Hitachi SJ-300 AC drive and a HXSP-2108G RS422/485 to USB interface that I need wired. The interface's user manual did not help me at all.
On the interface side I have:
T-/A
T+/B
R+
R-
GND
9V
On the drive I have:
SP
SN
RP
SN
I understood I needed to connect it like this:
T-/A <----> SN
T+/B <-----> SP
Then jump RP to SN for termination.
That isn't working for me. The drive, the interface and myself are new to each other so the problem could be wither either three.
On a related note, the motor runs as high as 1.5Hz and if I continue to twist on the speed pot, the drive will fault with a "motor overload" error. It's a 25 HP motor not attached to anything yet. The motor is also new so I don't know for sure if it's good. It's 9 lead wired Delta, low voltage config: L1=1,6,7, L2=2,4,8, L3=3,5,9. Clues?
Thanks,
JR
hitachi etien4 Phase Converters and VFD 0 02-28-2010 11:58 AM
looking for hitachi help cnc_class Fanuc 3 01-20-2009 07:10 AM
Hitachi VFD ? QSIMDO Phase Converters and VFD 13 12-03-2008 11:24 AM
Hitachi 6M Spinner Plasma, EDM and other similar machine Project Log 0 07-06-2007 01:21 PM
Sj300 Vfd mmachining Phase Converters and VFD 0 09-06-2006 08:59 PM
