| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
hello dont know if this is the right place to post this question but here it goes . I got this wood lathe and I would like to run it out of my garage from the 220electrical outlet . can someone guide me in the right direction by let me know what is the biggest horsepower motor I can go up to . thanks |
| You would need to know the wire size used for the outlet and the breaker size? Al.
| It would be rare to find a motor over 5hp that would run on single phase. How ever 220 outlets have different amp rating depending on their original intended use. You should have an electrician check your existing outlet you plan on using and he can determine what size load it will take. And 5hp is exteme overkill. You also dont mention the lathe model make or size. Most home hobby lathes will work fine with no more than 1 1/2 hp or smaller. Mike |
| thanks for the replies and yes I would like to use a VFD and also bassically all I want to do is since I have is the dryer electrical outlet in my garage and I dont use it what I was thinking of doing bassikly have a wire cored connect to the VFD that it would connect to the electrical dryer outlet. hope that makes some kind of sence if not please let me know how I can go about hooking this up. thanks again. |
| Most likely it will be wired in 10g, if so it will be good for 30amps ~7.5hp. If using a VFD you won't be plugging the motor but you most likely will not be going with that large of a motor. Al.
| Newbie- Every CAD prog claims to be the world's biggest and best... | adamshive | General CAM Discussion | 3 | 07-30-2009 11:35 AM |
| Biggest end mill in aluminum? | DeusExMachina | Taig Mills & Lathes | 15 | 05-01-2009 11:03 PM |
| The BIGGEST THK rails ever!!? | DennisCNC | Linear and Rotary Motion | 22 | 03-15-2006 05:03 AM |
| what's biggest part you can make on an X2 | sanddrag | Benchtop Machines | 2 | 03-04-2006 12:58 AM |
