Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 04-27-2005, 12:32 PM
zcases's Avatar
zcases is on a distinguished road
choices, choices
A friend has offered (both for the same price) to sell me a motor for me to make my RPC with. His two motor choices are below. I will be running (not necessarily all at once) a manual 1hp Bridgeport, 2 Boss 5 2hp CNC Bridgeports, a DoAll 1hp bandsaw, ~6hp total.
I already took him up on the 10hp before I saw this new forum. Should I reconsider? I like the 10hp since its smaller, draws less current, and the higher rev's should be a slight phase angle advantage (if I would notice it). It should be adequate for me for a while until I get a VMC someday with a larger motor. I thought the 15hp may have been a little quieter. But it draws a lot more current. The 10hp I already have an adequate line to supply it.
I am replacing a 2hp converter if anyone is interested in that one.
1) 10hp, 240V 26A 3650 rpm
2) 15hp, 200V, 45A 1700 rpm
Old 04-27-2005, 01:16 PM
Al_The_Man's Avatar
All the information feedback I got when I built mine was a 4 pole 1700 motor was preferable, evidently it is easier to tune and initially get up to speed. But regarding size, you can run up to twice the HP of the converter if it is a 3ph motor load, as long as the largest motor is no larger than the converter motor.
Here is another link I used.
http://www.metalwebnews.com/howto/ph-conv/ph-conv.html
Old 04-27-2005, 03:48 PM
Gold Member
lerman is on a distinguished road
My understanding is that the converters are rated on the size of the motor they can START. You can run motors several times the rated horsepower of the phase converter. So, a two horsepower phase converter might actually be able to handle your entire six horesepower load. If you start them one at a time.
I am not an electrician, nor do I play one on TV.
Ken
Kenneth Lerman
55 Main Street
Newtown, CT 06470
Diy Power Supply Choices berin DIY-CNC Router Table Machines 11 07-13-2005 04:47 PM
Augh. Too many choices in CNC control software MadMax General CNC (Mill and Lathe) Control Software (NC) 4 07-08-2005 02:00 PM
Software choices Paul in OK General CAM Discussion 4 04-28-2005 09:47 AM
Choices for machine to convert cspmiata Benchtop Machines 2 04-18-2004 11:53 PM
Router choices wjbzone DIY-CNC Router Table Machines 9 10-12-2003 01:23 PM
