Huanyang VFD RS485 / Modbus - Page 5
Page 5 of 11 FirstFirst ... 2345678 ... LastLast
Results 49 to 60 of 124
Thread: Huanyang VFD RS485 / Modbus
  1. #49
    Registered phomann's Avatar
    Aug 2005
    Unless things have changed, the Haunyang VFDs have not implemented Modbus correctly. You will not get it to work without rewriting the Modbus master code to suit the Haunyang interface which is not Modbus.
    Cheers,
    Peter
    Homann Designs - http://www.homanndesigns.com
  2. #50
    Feb 2007
    Quote Originally Posted by gnomathibus View Post
    Hello, I begin with EMC2, I try to install the plugin vfd and I have the following error message:
    Makefile:17: .o/hy_vfd.d: Aucun fichier ou dossier de ce type
    Makefile:17: .o/hy_modbus.d: Aucun fichier ou dossier de ce type
    mkdir -p .o
    cc -I/usr/include/linuxcnc -URTAPI -U__MODULE__ -DULAPI -Os -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -MM -MT ".o/hy_modbus.d .o/hy_modbus.o" hy_modbus.c -o .o/hy_modbus.d.tmp \
    && mv .o/hy_modbus.d.tmp .o/hy_modbus.d
    hy_modbus.c:37:19: error: rtapi.h: Aucun fichier ou dossier de ce type
    make: *** [.o/hy_modbus.d] Erreur 1
    If somebody in an idea
    If you are using linuxcnc 2.5.0, the source will have to be edited to fix. basically find and replace emc2 -> linuxcnc a bunch of times. There are probably some other things that need to be done also. What you have to do is see what the error is telling you and figure out how to fix it. for example "Aucun fichier ou dossier de ce type" No such file or folder. You need to install source and library files to be able to compile programs.
    Also, know that you don't need to compile, you only need to copy the binary executable hy-vfd to /usr/bin
    Also, the file custom-postgui.hal gets overwritten every time stepconf is run, so make a backup to copy back if you use stepconf.
    I saved my files, you can try them and see if it works for you.
    Attached Files Attached Files
  3. #51
    Oct 2011
    france
    thank you very much for your help alan_3301, now when I run emc2 I get this error:
  4. #52
    Feb 2007
    custom.hal is trying to assign motion.spindle-forward, but it has already been assigned. what you need to do is go into your machine .hal file, find the line that mentions motion.spindle-forward and spindle-cw on the same line. comment this line out (what that means is put a # at the beginning of the line)
    See what happens with that. you should be close to getting the software side of things set.
  5. #53
    Oct 2011
    france
    ok now linuxcnc is launched without error , the control panel Huanyang vfd is present but when I run the command "M3 S10000" nothing happens, yet my VFD is configured
    PD001= 2, PD002 = 2, PD163 =1, PD164 = 2 and PD165 = 3, my COM port is ttyS0
    I tested my spinle on windows with the plugin Huanyang vfd for mach3 and it works without problems
  6. #54
    Oct 2011
    france
    I found it works with: loadusr spindle-Wn-hy_vfd vfd vfd-spindle-n-d / dev/ttyS0-r 19200-b 8-p none-s 1-t 1
    thank you again for advice
  7. #55
    Feb 2007
    If you issue a M3 S10000 does your spindle run at 10,000rpm?
    I am having issue with my vfd and spindle going at 8x the rate at which my S command specifies.
    are you using the linuxcnc2.5 hy_vfd binary in the zip file I posted earlier, or are you using a version you compiled yourself?
    This will tell me if i need to look on the linuxcnc side of things, or the VFD.
    would you mind posting your pd008 and pd144 settings.
  8. #56
    Feb 2007
    I think I figured it out. When scotta wrote this program, I guess he used the default for pd004 on his VFD/Spindle.
    In the file hy_vfd.c look for
    Code:
    hzcalc = *(haldata->base_freq) / *(haldata->rated_motor_rev);
    	freq =  abs((int)(*(haldata->speed_command)*hzcalc*100));
    base_freq is pd004 (default of 50)
    rated_motor_rev is pd144 (default of 1440)
    I am assuming when he set his VFD up, and wrote the program, that he set pd144 to 3000 like the rest of us using this spindle, but left pd004 at 50?
    this would set hzcalc to 0.01666667 When I set my pd004 at 400 as instructed by the consensus. it would set hzcalc 8 times more, to 0.13333333
    Which explains why my vfd tries to run at 8x the speed of my S command.
    So to fix I will change to
    Code:
    hzcalc = 50 / *(haldata->rated_motor_rev);
    this should work for all cases. The definition of rated_motor_rev is the speed of the motor at 50hz, so this should be good for all.
    I will test it out this week and make sure it all works.
  9. #57
    Aug 2012
    Israel
    Alan, I find this useful and interesting. I just got a new CNC engraver with 800w VFD water cooled spindle. The VFD inverter is probably Huanyang but there is no brand or model name on the outside. The front panel has start and stop buttons and a speed potentiometer. The other buttons were hidden by a large warning sticker that i should not change parameters.
    How do I know if I can use it with code presented here?
    Anyway I have ordered a rs232 to rs485 converter from ebay and I would like to try this when it arrives.
    Thanks!
  10. #58
    Feb 2007
    Hi, the best thing I can tell you Is to look on back / bottom of the vfd for a model # or sticker with info. Then you can try to find a manual somewhere. It might be the same as the one floating around for the vfd that comes with the 2.2kw spindles.
    The next step would be to go through each parameter, and write down what each one is currently set at. I think you avoid should viewing pd013 as it supposedly resets all other settings, but according to my manual you have to set it to 8 to do so.
    Definitely find a manual and read what all the parameters do as much as you can stand, it will help when things arent working.
    Also, some of the VFDs did not come with the rs485 chip installed.
  11. #59
    Aug 2012
    Israel
    Sorry, my confusion! The model that I got is HY01D523B.
    I'm attaching a photo of the front panel and interior.
    If I understand correctly, the RS485 chip is U4 (8 ping chip on the right edge under the ribbon cable and the two electrolytic capacitors).
    Attached Thumbnails Attached Thumbnails Huanyang VFD RS485 / Modbus-inverter-jpg
  12. #60
    Dec 2003
    I understand you intend using with EMC, but maybe by looking at details of the Huyanyang serial plug in in the Mach site will give you insight to the Parameters that were used in that plug in.
