Many thanks.No it is poorly connected on top, the plug body has a insulator between it an the main body of the spindle, this is how your spindle should be connected, most of these spindles need the 4th pin connected this is what is needed, it's not only your Ground that is not connected correct, the cable shield also need to be connected, which is not
Sent from my SM-G935F using Tapatalk
