Vfd spindle just stopped spinning. - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 41
Thread: Vfd spindle just stopped spinning.
  1. #21
    Jun 2017
    United Kingdom
    Default Re: Vfd spindle just stopped spinning.
    You may not be allowed to change it, did you enter PD200=65535 first
    No....what is this? You never put it on the list above.
    What are 200 and 209?
    Sent from my SM-G935F using Tapatalk
  2. #22
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by potts43 View Post
    It's also in what you posted about your VFD and Spindle, first you enter PD200=65535 then this should give you access to Change PD209
    Mactec54
  3. #23
    Jun 2017
    United Kingdom
    But what does that do to the vfd?
  4. #24
    Jun 2005
    Mactec is correct this was not done very well. First check the incoming voltage it should be 220v to 240v and that is normally connected toR and S. If you have the right incoming voltage something probably died in the VFD. Mantec has worked on lots of these units.
    Russ
  5. #25
    Jun 2017
    United Kingdom
    Quote Originally Posted by CNCMAN172 View Post
    Russ
    Thanks Russ. Think I'm reaching the same conclusion too.
    You say connect to R and S .....He said connect to R and T....im confused now.
  6. #26
    Jun 2017
    United Kingdom
    Is it worth replacing this unit for another identical one or another brand? Can you recommend others?
  7. #27
    Jan 2005
    As I said they can be wired single phase to any 2 terminals, R and T has been the most successful way to wire these VFD Drives, there are other manufactures that require to be wire to there spec's only, you have no choice like these cheaper drives
    Mactec54
  8. #28
    Jun 2017
    United Kingdom
    Tried all you have suggested and the error remains.
  9. #29
    Jun 2005
    potts,
    Did you check the incoming voltage is it between 220v to 240v? Is so you had something die in the VFD. These Huanyang VFDs are probably the cheapest units you can find, but you might want to consider a Hitachi, lots of people get those they usually cost about $75 more but the quality and the manuals are much better. You need the one for the 2.2KW spindle based on what you posted previously. Search the zone and you will find the exact model number. Since this is low voltage error you might have only lost components in the VFD itself, many times the VFD and Spindle both go at the same time. I would take an ohm meter and unplug the Spindle and measure from the case (ground) to each of the phase pin connectors to ensure the spindle is no internally shorted, especially prior to attaching a new VFD.
    Russ
  10. #30
    Jun 2017
    United Kingdom
    potts,
    Russ
    Ok....what reading should I expect to see at each pole?
  11. #31
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    A bit more than $75 more...
    Huanyang = $135.
    Hitachi = $325
    UCCNC 2017 Screenset
  12. #32
    Jun 2005
    The readings from each pole to ground should be pretty much open, meaning no reading. Then when you measure between each phase you should get something 2-3 ohms a low reading. You are trying to verify that no phase got shorted to the ground case of the spindle. Sometimes that happens when a spindle is run too slow and the wire gets so hot is melts the insulation and the short results. These spindles are designed to run from 6000 rpm to 24,000 rpm. In fact the VFD should be programmed so the lowest frequency is 100hz, which equates to 6000 rpm.
    Gerry,
    Wow, the Huanyang got lots cheaper than when I purchased mine a long time ago. The $325 for the Hitachi should about right from what I recall, so that has not moved very much. I got mine as a spindle vfd combo so probably why my view was outdated.
    Russ
    Russ
  13. #33
    Jun 2017
    United Kingdom
    Quote Originally Posted by ger21 View Post
    Huanyang = $135.
    Hitachi = $325
    What is the model of the Hitachi? I've been quoted £340 for a Vacon 20. I'm hoping there's something cheaper.
  14. #34
    Jun 2017
    United Kingdom
    2.2KW - VACON 20 VACON0020-1L- 0009-2 EMC2 QPES - IP20
  15. #35
    Jun 2017
    United Kingdom
    It worries me to buy something else and not know how to wire it up.
  16. #36
    Jun 2017
    United Kingdom
    Is it a Hitachi WJ200-022SF ?
    The 2.2kw one is £450! Ouch
  17. #37
    Mar 2003
    Shelby Township
  18. #38
    Jan 2005
    The Drive then is most likely damaged, it sounds like the current sensor has failed, higher quality VFDs can be more forgiving, but if the wiring to the spindle is not corrected the same thing could happen
    Mactec54
  19. #39
    Jun 2017
    United Kingdom
    Do you mind me asking what is wrong with the earth? It is connected on the top and at the vfd?
  20. #40
    Jan 2005
    No it is poorly connected on top, the plug body has a insulator between it an the main body of the spindle, this is how your spindle should be connected, most of these spindles need the 4th pin connected this is what is needed, it's not only your Ground that is not connected correct, the cable shield also need to be connected, which is not
    Attached Thumbnails Attached Thumbnails Vfd spindle just stopped spinning.-ground-wire-2-jpg   Vfd spindle just stopped spinning.-spindle-ground-shield-connections-png
    Mactec54
