Looks like you bought a Huanyang copy, rather than a real Huanyang.
My perfectly running hy02d223b with mach3 control went POP a couple weeks ago. The replacement hy02d223b does not have the second terminal bank in it where the rs+ and rs- connections went. My response from the ebay supplier is as follows, please help me decipher it if you understand;
greatfunctionitem:
replied as below:
Hello, your current this please use external speed control,
Segment speed control performance better,
And more versatile.
The parameters are as follows:
Pn32 = 3
Pn03 = 7
Pn04 = 2
Pn07 = 2
Pn10 = rated motor frequency
Pn12 = rated motor frequency
The external segment speed is as follows:
The hardware connection is as follows
D2: D1: D0 Three control lines are valid as follows
1: 1: 1 speed 7 (PN26) speed
0: 1: 1 speed 3 (PN22) speed
0: 0: 0 speed 0 (PN19 specifies the frequency source, the current specified PN02 speed)
If you do not understand anything, please tell me that we are working hard to solve the problem for you.
Thanks,
Jerry
Boise
- Need Help!- hy02d223b E.ov.A
- Need Help!- Daewoo 8s parts catcher missing. Need to fab a replacement
- Need Help!- RS485 commands for Huanyang VFD (HY02D223B)
- HY02D223B VFD
- rs-232 and rs485 bus
UCCNC 2017 Screenset
