No, just get a single phase capable VFD.
Sent from my A3-A20FHD using Tapatalk
I own a small spindle repair shop. I would like to be able to "run in" rebuilt motor/spindles before I return them to my customers. Should I convert to 3 phase with a rotary. Then control speed (hz) with a VFD.
There would be no load on the spindle motor but I want to be able to run up to full operating speed. Any experts out there?
Thanks,
Glides
- Need Help!- 220V single phase VFD 3 phase output for powering a 200V 3phase AC Servo drive/motor
- Robodrill 7.5hp spindle. Single Phase Power input No Rotary Phase convetor doable?
- driving a single phase capacitor start/run motor from three phase vfd or power grid.
- Need Help!- how to connect single phase spindle motor with 3 phase inverter
- fitting a 110v or 220v single phase spindle motor on a 3 phase machine
The single phase vfd units I have researched only go to 60 hz. To run to full rpm I think I need more than that.
I assume you are talking 3ph spindles? If so you do not need a RPC, just a VFD ran off of 1ph 240.
What's the biggest Hp Spindle you are doing, or do you just want to run a belt drive for testing and have a small Hp Ac 3Ph motor to just run/test the spindle with
So your motor Hp is the first thing you need to know, from this then you can get the right size VFD to suit the AC 3Ph motor you want to run, no RPC is needed unless you have a large Hp motor, to control the speed that is the easy part, and is what all VFD Drives do
Mactec54
