- Phase Converter 15 HP CNC Softstart
Re: Phase Converter 15 HP CNC Softstart
Darn, kind of far from Florida.
It can be shipped there for about $100.
I looked on American Rotary's web site but didn't see that model. How large of a motor will it start?
I'm not sure but it's rated at 15HP so I assume close to 15HP.
They usually start a motor that is about half the idler. I just bought a Mazak QT-8 CNC lathe and it came with an American Rotary AD10. It will run the lathe, but just barely. Rapids or higher spindle speeds will alarm out due to voltage drop. Do you have a manual for yours?
I think. Let me check the back of the front panel.
This one is pretty good. It's made for cnc so the output can be closer to the idler. The panel says max. of 3-phase 42 amps. out and when converted to hp at 230V that is a 15hp motor.
The one I have is also rated for cnc, it's just not big enough. I'll PM you.
Thanks, I'll look it over.
Turns out I don't need it, thanks anyway. I just bought a 10 HP motor so I can double my existing 10 HP RPC by adding some run caps.
Good luck selling it.
ok, darn. Thanks for letting me know. Cool you can add a motor and caps like that; i might look into that.
- You may not post replies
- You may not edit your posts
Forum Rules
