Phase Converter 15 HP CNC Softstart
Results 1 to 15 of 15
Thread: Phase Converter 15 HP CNC Softstart
    Sep 2006
    Default Phase Converter 15 HP CNC Softstart
    Hi! I am looking to sell my Rotary Phase Converter. It is in like-new condition; only ran a few times. See attached pics. I was looking for $500-1000 price range. This is an awesome find for anyone needing a medium size rotary phase converter for CNC or other.
    Phase Converter 15 HP CNC Softstart-15-hp-phase-converter-jpg
    Phase Converter 15 HP CNC Softstart-phase-converter-plate-jpg
    Oct 2005
    Default Re: Phase Converter 15 HP CNC Softstart
    Where is it located?
    Sep 2006
    Warren, OH
    Oct 2005
    Darn, kind of far from Florida.
    Sep 2006
    It can be shipped there for about $100.
    Oct 2005
    I looked on American Rotary's web site but didn't see that model. How large of a motor will it start?
  7. #7
    Sep 2006
    I'm not sure but it's rated at 15HP so I assume close to 15HP.
  8. #8
    Oct 2005
    They usually start a motor that is about half the idler. I just bought a Mazak QT-8 CNC lathe and it came with an American Rotary AD10. It will run the lathe, but just barely. Rapids or higher spindle speeds will alarm out due to voltage drop. Do you have a manual for yours?
  9. #9
    Sep 2006
    I think. Let me check the back of the front panel.
  10. #10
    Sep 2006
    This one is pretty good. It's made for cnc so the output can be closer to the idler. The panel says max. of 3-phase 42 amps. out and when converted to hp at 230V that is a 15hp motor.
  11. #11
    Oct 2005
    The one I have is also rated for cnc, it's just not big enough. I'll PM you.
  12. #12
    Sep 2006
    I received the manual. See attached.
    Attached Thumbnails Attached Thumbnails Phase Converter 15 HP CNC Softstart-old-arc-installation-manual-pdf
  13. #13
    Oct 2005
    Thanks, I'll look it over.
  14. #14
    Oct 2005
    Turns out I don't need it, thanks anyway. I just bought a 10 HP motor so I can double my existing 10 HP RPC by adding some run caps.
    Good luck selling it.
  15. #15
    Sep 2006
    ok, darn. Thanks for letting me know. Cool you can add a motor and caps like that; i might look into that.
