it also has these pins
ok I bought this vfd its a kinda 2.2/22v vfd model kd200-00220s2 I tried to contact my supplier and the company with nothing...it says 220v and from what I know is that r,t,s + ground for 220 but mine only has scews terminals with ground r and t ...here are some pics thanks to all advance
Those two pins are for RS485 control of the VFD from the computer link. You will also need a USB to RS485 converter to setup that link if you plan on using Modbus to control the VFD.
You only need those two connections for 220V. Check out the manual.
I don't know what you have in your Manual, they have a very good manual on there website, here is a snip showing the wiring, it can be quite normal for a single Phase VFD Drive to only have the R ( L1 ) and T ( L2 ) Power connections, this is a very good VFD compared to other cheap VFD Drives, it has Auto Tuning, so there are only a few Parameters that have to be set correct, then you can use the Auto Tune and you will be set
Mactec54
