Do a search for the old Fitch Williams RPC design, it should have the tuning features included.
I picked up a hardinge conquest 42 with a 10hp (7.5kw) spindle. Looks like it requires about 60 amps for 115% full load. The guy I got it from said he ran it off a 50 amp breaker and it ran fine.
Probably picking up a 30hp motor tomorrow. Anything specific I should be looking for when I get the motor? The plate on the motor said it requires 78 amps. Will this also be the case if I'm just using it as an idler?
I guess my first question is how do I calculate a rough estimate for how many and how big capacitors I should get.
Sent from my SM-N920V using Tapatalk
- Just IN- Jet Edge Introduces 60KSI 30HP Water Jet Pump for Shops with Limited Power
- FABTECH 2014: Titanium-Cut CNC Plasma Table with Two 5-Axis Bevel Heads & 30HP Drill
- 30Hp phase perfect convertor large enough for a Qt20 ?
- Problem- Building and setting up a balanced RPC
- New Photos! Horizontal Boring Mill (30HP)
I've been doing some reading. Seems like people are recommending about 15uf per 1 hp on the run side. Does that sound about right?
Also should I run a separate 220 line for the first 2 phase to the machine from the panel box and use just the rpc for the generated phase?
The Fitch converter:
404 Not Found
The past two times I edited this post, the URL was magically changed to cnczone. Here it is in words:
www dot cnczone dot com slash FitchWConverter dot pdf
No idea why it gets changed.
Third attempt. Something is autoediting my post and changing the word "practical machinist" (with NO space) into "cnczone". I have attached the pdf.
I found it and read it thanks.
Is trying to run a 30hp with say a pony start a stretch for 100 amp service? The load Motor is 10hp and takes 22 amps. I also have 2 servos which are 7.6 amps.
Quote " 15uf per 1 hp on the run side..."
15 didn't work for ME, but 17 did.
