Need Help! VFD Error Code - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: VFD Error Code
  1. #21
    Dec 2016
    United Kingdom
    Default Re: VFD Error Code
    i find i have the same problem..i have disconnected every cable apart from the 240v input and it still comes up with e30.1 does this mean the vfd is toast or maybe the rfi filter thats inline just before it
    any help appreciated
  2. #22
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by steve78 View Post
    What is the VFD you have, I guess it is the same as in this post, then check how you have it wired, in the UK you would have, ( 1 Hot ) Neutral and Ground / Earth connected, this is different from the USA, which is what the first post is about
    Mactec54
  3. #23
    Dec 2016
    United Kingdom
    its a hitachi wj200 it has been working fine with a 24000 rpm chinese 2.2kw spindle . then the error came up . as said i plug everything apart from power in and it still has the error code
  4. #24
    Jan 2005
    You will have to clear the fault, follow the manual on how to do this,\
    To get this fault, you may not have set the correct Parameters in the VFD that suit your spindle, this is the normal cause of problems like this, wiring also can cause this problem
    Have you checked the spindle Ground / Earth connection, Pin #4 has to be connected to the spindle most are not and need to be corrected
    Mactec54
  5. #25
    Dec 2016
    United Kingdom
    thanks for the help but i have read the manual and i cannot find how to clear the alarm error code if any knows how that will be a great help
  6. #26
    Jan 2005
    You will have to fix your wiring, even if you are able to reset the VFD, post some photos of your wiring, do you have shielded cable for the spindle, and is the shield correctly terminated
    Only some of the manuals have this information
    Attached Thumbnails Attached Thumbnails VFD Error Code-fault-reset-jpg
    Mactec54
VFD Error Code
VFD Error Code
