Page 1 of 4 1234 LastLast
Results 1 to 12 of 38
Thread: Making solar tracker. First time milling PCB, requesting help.
    Registered Burnit0017's Avatar
    Nov 2009
    Greetings to all. I am new to the forum. The cold weather is preventing working outside on other projects. I am currently working on a solar tracker. I have completed the motor control circuit and would like to try fabricate the pcb’s using my Zenbot. I am using ExpressPCB to layout the board. It will allow a dxf file to be created but it does not include the trace pattern. I use TurboCad to redraw the trace pattern. Then I use LazyCam to create the g-code. I run the Zenbot using Kcam and I have cut many usable parts with it but this is my first attempt at making my own pcb. I am able to draw the traces for a 2 sided pcb . If anyone can share there experiences making a two sided pcb , how to keep both sides lined up, is there a Dremel bit that can be used, or free download software that would make the process easier? Please let me know.
    Attached Thumbnails Attached Thumbnails Making solar tracker. First time milling PCB, requesting help.-regsizemccircuit.jpg   Making solar tracker. First time milling PCB, requesting help.-azrunesuntracker.jpg
    Aug 2005
    pcb milling
    Burnit,
    Sounds like a great project.
    For circuit milling bits check out www.drewtronics.net I use the 60 deg bits mostly.
    When milling your first side of a board it helps to drill 2 holes through your board and into a spoiler board below, then when you flip the board over you can place pins in the holes to align the board for the next side, this works really well, but there are lots of other ways, I am sure others will share their ways with you.
    Also google pcb-gcode for eagle if your interested. I know your not using eagle to design your board, so this may not be any help to you, but alot of folks are making their boards with that combination.
    hope this helps!
    Andrew Abken
    www.drewtronics.net - PCB Cutters
    Jan 2005
    Toronto, Canada
    I am curious about your circuit. What prevents both transistors on the same side from turning on simultaneously and destroying the fets?
    As for PCB milling, have you tried toner transfer instead? I find it to be less effort and can do fine pitch (8 mil) double sided boards with ease. If you use copper chloride for etching, then there's also no costly consumables.
    Apr 2003
    Quote Originally Posted by Burnit0017 View Post
    You might want to look into PCBGCODE as it works to create the milling paths directly with eagle..
    http://www.pcbgcode.org/
    Garry
    Nov 2009
    Greetings, the back to back and then vertical placement of the sensors sets is what should allow the circuit to work. A project in Berkeley is using the technique. The video shows how to mount the sensors far better than can possibly explain it.
    "http://www.youtube.com/watch?v=iH49Xd_NV3A"]YouTube- Solar Tracker (Berkeley ME102 Project)
    Nov 2009
    back to back and vertical sensor placement
    Quote Originally Posted by H500 View Post
    Greetings, the back to back and then vertical placement of the sensors sets is what should allow the circuit to work. A project in Berkeley is using the technique. The video shows how to mount the sensors far better than could possibly explain it.
    Registered Drools's Avatar
    Feb 2009
    Very cool demo, looks like an interesting project. I would look at eagle as well, I'm not sure how big your circuit board is but the free version might do what you need.
    Nov 2009
    I tried some test cuts on a blank board and the results where dismal, aka not good. Some parts of the traces cut to deep and other parts not at all. I definitely have to fabricate a better fixture. It did show that the software and procedure I used does work, but there is a lot of room for improvement. All in all a good learning experience. I am checking out the Eagle software.
    Nov 2009
    Same circuit, halve the cuts.
    When making modifications to a pcb layout I noticed a way to make less cuts. The patterns are the same circuit. The one on the left requires less cuts.
    Can anyone suggest a simple Font that can be used on a pcb layout?
    Attached Thumbnails Attached Thumbnails Making solar tracker. First time milling PCB, requesting help.-modazrunepowerdrivecnctop.jpg
    Dec 2004
    Memphis, TN
    You should look into the pcb-gcode and Eagle. What size bit are you coding for? make sure you give yourself enough isolation to avoid solder bridges. I personally like 20mils isolation on my circuits.
    Jay
    Nov 2009
    fabricating fixture
    Quote Originally Posted by Jay C View Post
    Jay
    Greetings, I have some small Dremel bits that I am trying to use until I purchase something better. I am currently fabricating a fixture to hold the pcb. I read in another post to mill the fixture flat first after it is installed to insure it is parallel with the cutting bit. After that we be ready to try another test cut. Thanks and best regards.
    Dec 2004
    Memphis, TN
    Perpendicular Yes, surfacing is the best way to get a flat surface relative to the spindle. Also, when you mill, make sure the copper is fully supported. I use carpet tape under my boards to hold them. Are you also trying to use a Dremel? They are notorious for runout that makes using them for smaller traces an iffy proposition, and a danger to more expensive micro bits. The least expensive bits are also my favorites are from www.drewtronics.net.
  • Page 1 of 4 1234 LastLast
    1. Need Help!- Stepper motors for a solar tracker project
      By Rohan2008 in forum Stepper Motors and Drives
      Last Post: 07-12-2012, 12:47 PM
    2. Bright future in solar??? New plastic solar
      By carbidecraters in forum Environmental & Alternate Energy
      Last Post: 04-06-2009, 12:49 PM
    3. milling time (not to be confused with hammer time)
      By barefoot0 in forum G-Code Programing
      Last Post: 05-02-2007, 07:18 PM
    4. Making bridges for milling
      By EddyK in forum Solidworks
      Last Post: 10-30-2006, 04:21 PM
    5. servos to control dual axis solar tracker
      By BullCreek in forum Servo Motors and Drives
      Last Post: 08-15-2006, 09:04 AM
