Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PCB milling
PCB milling Discuss PCB milling here.
Old 11-05-2009, 06:58 PM
powerr is on a distinguished road
3mm square 16 pin QFN
i attached a few pictures if a pcb for allegro 6281 16 pin QFN package, and of my mill that i use. i never thought i would get this to work.
i converted my sherline mill to 3/8 ball screws and antibacklash nuts. used
a A2ZCNC mill saddle for the base of the conversion. installed keling servo motors with 2500 cpr encoders to get the resolution i wanted on X and Y axis of the machine.
used a precisebits 45 degree cutter with a .0025 depth of cut for the etching.
Rob
ID:	92779   Click image for larger version
ID:	92780   Click image for larger version
ID:	92781   Click image for larger version
Old 11-05-2009, 11:43 PM
Arquibaldo is an unknown quantity at this point
a few questions
Dear Powerr:
Beautiful work - congrats. Unfortunatelly, the 3rd photo is out-of-focus. Do you have
another, showing the assembled PCB?
How did you solder the tiny IC? by hand? did you use a stencil?
Do you have a thread about the CNC conversion of your sherline mill? I would be very
interested in seeing it...
Nelson
Old 11-06-2009, 09:41 AM
Drools's Avatar
Drools is on a distinguished road
Yes that does look very nice. I to am interested in the build information used on the sherline in particular the servo setup.
Are you using Eagle with pcb-gcode and Mach3?
Old 11-06-2009, 02:09 PM
Arquibaldo
i soldered the chip on there using a basic hotair tool. i will do another board and take pictures of the steps as i go.
i dont have a build of the machine so to speak but i will take the paper guards off and take some more pictures. and explain what i did.
drools
yes that was using eagle, mach3, and gecko drives
Newbie- Square hole in square tube bubblybill General Metalwork Discussion 6 09-20-2009 11:18 PM
Need Help!- Back to square one... SpeedsCustom LinuxCNC (formerly EMC2) 45 03-06-2009 04:53 PM
Square hydrogen DIY-CNC Router Table Machines 8 05-28-2008 12:39 AM
How square is square and how to get there? Roguish Mechanical Calculations/Engineering Design 14 01-31-2008 08:16 AM
WOn't cut square! Ed_R DIY-CNC Router Table Machines 51 03-23-2006 06:19 AM
