Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PCB milling
PCB milling Discuss PCB milling here.
Old 10-11-2009, 02:43 PM
Drools's Avatar
Drools is on a distinguished road
Pcb-gcode question Bug?
I have been tinkering with the isolation settings on my PCB layout and I'm getting a weord result with some settings. Maybe someone here can shed some light on what is happening.
Here is a picture of my PCB layout in Eagle notice the USB connector hangs out over the PCB mill outline. This is where I'm thinking the problem starts.
Notice the PCB-Gcode output it adds an etch line outside the milling outline. It only does this when I set the: Isolation-->Maximum > .01. Under .01, I do not get very much isolation but it does not add this extra milling.
Doing singles on scrap pieces of PCB this is fine however if doing a dual board side by side I then have to waste the extra PCB material.
It would be nice if when determining the gcode, pcb-gcode would do a check for the milling outline and stop if there.
Old 10-12-2009, 11:42 AM
Jay C is on a distinguished road
Word of warning. Make your milling outline the same size as the bit you will be using to cut it. That way you can see if you will be slicing into your pattern, which I suspect you will be like this.
As for the extra outline, I've never seen that before. Does mach3 show that same outline?
Old 10-12-2009, 12:13 PM
Drools's Avatar
yep, Mach3 shows the extra outline. I will post the question on the pcb-gcode forum.
Old 10-13-2009, 05:20 PM
pminmo's Avatar
pminmo is on a distinguished road
Simple answer is to edit the gcode to remove the second outline. Is it in the mill gcode file or the isolation gcode?
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 10-15-2009, 09:41 AM
Drools's Avatar
hi Phil, the extra outline is in the isolation gcode. That just makes it a little harder to find and delete.
Old 10-15-2009, 11:14 AM
keebler303 is on a distinguished road
One thing you might try is to hide the layer with the component outlines. It looks like PCB Gcode is just finding the smallest rectangle your layot will fit into and then generating milling within it. If hiding the layer doesn't change it, you could always edit the component layout so that it didn't overhang the board.
You can use mach3 or ncplot to find the lines of gcode, both will highlight the line segment corresponding to the line of gcode you select. Pay attention to what Jay C said, PCB Gcode generates milling paths based on the centerline of the board outline, NOT outside it. If you use a cutter bigger than the thickness of your outline, it will cut into your board.
Matt
Question about GCode generator and open dwg jason4263 General CNC (Mill and Lathe) Control Software (NC) 2 07-15-2007 11:36 AM
Mach 3 GCode Question WarrenW Mach Software (ArtSoft software) 3 01-10-2006 01:43 PM
GCode Units question WarrenW G-Code Programing 2 01-04-2006 05:48 PM
Mach / GCode question WarrenW Mach Software (ArtSoft software) 11 11-19-2005 02:21 PM
