Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PCB milling
PCB milling Discuss PCB milling here.
Old 09-19-2009, 07:04 AM
Telly is on a distinguished road
CopperCam to Mach3
I'm testing out CopperCam to Mach 3. What output file format should I use?
When in importing to LazyCam using AutoCad-DXF file format it does not display correctly or not at all.
Any info would b great!
Thanks Telly.
Old 09-19-2009, 10:30 AM
Edit. Unlicensed version of coppercam.....durrrr silly me!
Old 09-23-2009, 04:41 AM
Zig Zig is offline
Zig is on a distinguished road
Coppercam calls for standard PCB fab data. Gerber and Excellon 2.
It outputs G Code which Your mach software reads directly.
Old 09-24-2009, 04:48 PM
i see. i don't import to lazycam.
thanks for that.
Need Help!- I cant get Mach3 to run Crawler374 Mach Software (ArtSoft software) 4 09-07-2009 01:11 PM
Mach3 won't keep zero! sp1nm0nkey Mach Software (ArtSoft software) 17 09-06-2009 04:21 PM
New Machine Build- Mach3 mrpeja Mach Software (ArtSoft software) 0 12-30-2008 05:22 PM
4to eje con mach3 dansa0561 Spanish CNCzone 3 07-31-2008 11:44 AM
want to see what mach3 is doing mike hide Mach Mill 3 03-03-2008 02:31 PM
