Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PCB milling
PCB milling Discuss PCB milling here.
Old 08-14-2009, 10:47 AM
Drools's Avatar
Drools is on a distinguished road
Via shape/size and wire size.
The board I want to make uses 2 Atmega48 chips in DIP (.3) format and some other supporting pieces on a single sided PCB. Very low power consumption so my traces do not need to carry much current. I'm using Eagle and I see that the VIAs can be 3 shapes, square, octal and round with a size attribute as well. What are the most common size and shape when making an Eagle board with the thought of exporting gcode using PCB-Gcode? Does wire size affect the final product?
I routed one board last evening using the default settings in the tutorial from this site, pminmo.com. The board turned out really nice, exactly what I had in Eagle but the pads are a little small to solder to because I used .04 size. I'm going to redo the brd with different pad sizes because I noticed there is a lot of copper left between the pins on the DIPs. I would rather this copper be on the pin side and not the waste side if you know what I mean.
Thanks again guys for your knowledge and experience on this.
Wire EDM - Wire Type and Size greenchair General Metal Working Machines 0 06-17-2009 02:44 PM
G540 wire size? bkboggy Gecko Drives 7 03-31-2009 01:04 AM
power supply size? for multi wire (total 250 inches of wire) DanOSB CNC Wire Foam Cutter Machines 5 03-02-2009 05:34 PM
vacuum forming size according to shape zimmerman Vacuum forming, Thermoforming Etc 4 07-03-2008 04:33 PM
Hookup wire size Monte Xylotex 0 02-20-2005 04:52 PM
