Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PCB milling
PCB milling Discuss PCB milling here.
Old 08-03-2009, 06:52 PM
kn6za is on a distinguished road
some prototype boards
Some boards I have been working on.
designed with eagle by cadsoft
gcode generated by pcb-gcode :Thanks to John Johnson for the software
www.drewtronics.net 60deg isolation router - shameless plug!
Home built milling machine
Nice to be able to make up a few prototypes this quickly.
ID:	85616   Click image for larger version
ID:	85617   Click image for larger version
Andrew Abken
www.drewtronics.net - PCB Cutters
Old 08-03-2009, 07:56 PM
Eurisko is on a distinguished road
Very nice work.
I've never tried pcb milling, what depth of cut did you use?
Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
Old 08-03-2009, 08:56 PM
Thanks,
Depth of cut was between .0018 and .0022 inch. I cut these just deep enough to get through the copper. I don't like cutting into the fr4 any farther than necessary.
Andrew Abken
Old 08-03-2009, 09:27 PM
mcphill is on a distinguished road
Nice work! VERY clean traces/edges - jealous!
Old 08-04-2009, 12:53 AM
Jay C is on a distinguished road
Looks great Andrew. Bet they took a while to rubout using a 60-degree bit (ask me how I know )
Old 08-04-2009, 09:01 AM
Thanks,
Yes, its not as fast as my laser printer, thats for sure! I ran these with a .0015" step over and tool diameter set to .005"
Andrew Abken
Old 08-04-2009, 10:29 AM
You can speed that WAY up by changing bits. Cut the traces with the V-bit, with a decent offset, then switch to something like a 1/8" bit to clear out the "field".
Old 08-04-2009, 01:23 PM
mcphill,
Good "point"! - Pun intended
Andrew Abken
Open Source Boards Available, Stepper Drivers and Break Out Boards pminmo Open Source Controller Boards 762 11-21-2011 11:51 PM
Another SMD prototype Jay C PCB milling 33 09-29-2009 01:30 PM
Prototype and possible run silverfoxx03 Employment Opportunity 1 05-18-2009 07:45 PM
Just IN- Prototype help please iwillinvent CNCzone Club House 0 05-29-2008 12:28 AM
pcb prototype xlukkajr General Electronics Discussion 2 02-21-2007 04:14 AM
