Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PCB milling
PCB milling Discuss PCB milling here.
Old 05-27-2009, 09:14 AM
ebidk is on a distinguished road
CNC PCB mill: Buy or DIY?
I want to have a CNC mill to make PCBs on.
Requirements:
Working area: 160x100mm, 320x200mm would be nice but is not needed.
Precision: Precise enough for SMD.
Price:
Max 250 EUR + shipping.
I have access to professional CNC mills and lathes for metal work for the next couple of months, so I'm wondering if I should buy one or make one myself using a dremmel or similar.
I've been doing a bit of math and it looks like I'll be spending about 50% of my max. amount on motors and I'm guessing about 25% on a dremmel(not sure what they actually cost here in Denmark) and that leaves not a lot for the mechanical parts.
If I build myself I will use EMC2 from linuxcnc.org as a controller.
If I buy I'm fine with a good condition second-hand machine too.
Last edited by ebidk; 05-27-2009 at 09:18 AM. Reason: Adding note on second-hand machines and EMC2.
Old 05-27-2009, 11:01 AM
PEU's Avatar
PEU PEU is offline
PEU is on a distinguished road
if you go the purchase way IMHO 250euros is not enough to purchase 3 decent steppers motors + stepper drives + metal/bolts/etc
Start by making a list of the items you will need and check again your numbers, also, if after a couple of months you don't have access to cnc machinery you may end up stalled in your build.
Do you have the DIY design ready?
Lots to think
Old 05-27-2009, 11:16 AM
Not entirely. I have a work in progress:
but it'll be redesigned some if I build my own, it will be a gantry design though.
If I settle on a final design soon it shouldn't have a problem getting the metal parts done in time.
Old 05-27-2009, 11:20 AM
Kipper's Avatar
Kipper is on a distinguished road
Looks like an optical illusion..... €250... Kinda tempted to sell you my new router....Shucks I managed to resist....
Keith
Old 05-27-2009, 11:40 AM
PEU's Avatar
PEU PEU is offline
finish your design, make an item list, cost them, then you will know
Old 05-27-2009, 12:12 PM
Motors:
http://dk.mouser.com/Search/ProductD...6nMhcaFYPOw%3d
Quantity: 3
Total price: 138.15 EUR
Dremel:
Quantity: 1
Total price: ? Can't find a local price anywhere, assuming 66.66 EUR(500 DKK)
Metal parts:
Quantity: 1 set
Price: ? depends on final design and choice of metal type.
So it's about the same amount, the better question is if I'll get a better mill for the money by buying or building. What can I expect of the average new or second-hand mill in this price range?
Old 05-27-2009, 12:23 PM
veteq is on a distinguished road
budget is at least 3 times 250 for DIY a good machine.
If you buy one think even more
Old 05-27-2009, 02:26 PM
acondit's Avatar
acondit is on a distinguished road
Originally Posted by ebidk View Post
Motors:
http://dk.mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMu0WtFXTgs3LvbD76Eq%252bivA6nMhcaFYPOw%3d
Quantity: 3
Dremel:
Quantity: 1
Metal parts:
Quantity: 1 set
You don't have the drives for the motors listed nor switches, wiring, power supply, bearings, or rails.
You can't just throw together junk and expect to accurately cut PCBs. Accuracy requires design and planning. Basically, you want as close to no flex and no backlash in your design as possible. I have cut PCBs with my router which was built with Thomson linear rails and bearings and I can successfully cut thru-hole stuff if I allow 0.020" traces but there is no way the current design will cut SMD stuff.
Alan
http://www.alansmachineworks.com
Old 05-27-2009, 09:28 PM
PEU's Avatar
PEU PEU is offline
IMHO these motors are weak, go at least nema23
Old 05-28-2009, 03:53 AM
Ouch, if I need to do that I'll overshoot my budget by 150 EUR just by buying the motors. http://sine.ni.com/nips/cds/view/p/lang/en/nid/203937
  #11   Ban this user!
Old 05-28-2009, 07:50 AM
that motors are to expensive,
the 23Y are 36 dollar a piece
http://www.anaheimautomation.com/pro...rs.php?vTID=75
  #12   Ban this user!
Old 05-29-2009, 03:43 AM
Aah, that's a lot more affordable.
Motors: 77 EUR
Dremel or similar: Assuming 70 EUR
Electronics: Assuming 50 EUR
Metal parts: ? EUR
Screws and such: ? EUR
Controller: 0 EUR, already got a spare PC that will run EMC2
Total: 197 EUR + metal parts and screws and stuff.
Tags
cnc mill smd pcb diy, dream-on
Where to find Shell mill / Face mill arbor for taig 725franky Taig Mills & Lathes 5 11-18-2009 05:48 PM
Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head fignoggle Benchtop Machines 18 05-12-2009 12:11 AM
RFQ - milling work on 1/4" wide tool steel - may need azis mill or right-angle mill pendentive Employment Opportunity 7 01-21-2007 08:56 PM
