Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PCB milling
PCB milling Discuss PCB milling here.
Old 05-07-2009, 09:13 PM
atferrari's Avatar
atferrari is on a distinguished road
What is next after buying the machine?
No experience in CNC at all.
I am a electronics hobbyist from long time and I want to mill make my PCBs with a machine that I have the chance to buy very cheap: a Proxxon modified by Usovo (Germany). I think it is a MF70 Euro 2008.
My questions:
Once I get the machine, what are all the other things I need to obtain to start milling (well, trying to) PCBs? Hardware and software?
Could you mention them in a logical sequence if at all possible?
I understand, from all what I have been reading that going from the CAD to the software driving the engraving machine is the hardest part.
Could you mention (reliable?) free software if at all possible.
Gracias for any help.
PD: BTW, engraving or milling?
Old 05-08-2009, 01:02 AM
kn6za is on a distinguished road
atferrari,
Welcome to the zone!
I will give you my take on getting started cutting your own circuit boards.
Hardware; cutting tools. I use and sell 60deg v-shaped tools for circuit board engraving, check out www.drewtronics.net There are many others selling tools for circuit board work as well, but I think mine are the best Other common angles people use are 30deg, 45deg, and 90deg. The shallower the angle the shallower the point on the tool, witch helps keep the cutting width of the tool uniform over the surface of a board that is not held down perfectly flat, or a machine that does not repeat z-depth accurately. 30deg tools have a delicate tip compared to the 90deg.
You will also need a method of holding the circuit board down flat. This is very important, and can make all the difference when it comes to surface mount boards especially. I use a vacuum chuck, but I have seen people use 2 sided tape, super glue, toe clamps. This will require some experimentation to find out what works best for you and the boards you produce.
Software; to design circuits = eagle : cost is free
Eagle can be tough to get started with, but just devote some time to it and you will find it gets better with time.
Software to convert eagle pcb design into g-code to run your mill = pcb-gcode : cost is free check out the yahoo group for it
http://groups.yahoo.com/group/pcb-gcode/
pcb-gcode works really well, its easy to use and has lots of people using it and supporting questions.
Hope this helps, have fun milling boards, its the best way to produce circuit boards at home in my opinion.
Andrew Abken
www.drewtronics.net - PCB Cutters
Old 05-08-2009, 11:59 AM
pminmo's Avatar
pminmo is on a distinguished road
Take a look at my video:
and website millpcbs.com on a simple holding and alignment method. Which BTW uses a Drewtronics bit...:-) At the end of the video you get some still pictures that give you a true perspective of the work.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 05-09-2009, 12:04 AM
One of my FAVORITE online videos
Phil is always working on something cool.
Being able to make circuit boards like that at home is just amazing. Makes prototyping with surface mount components much easier.
Andrew Abken
Old 06-18-2009, 08:49 PM
atferrari's Avatar
Milling and / or engraving?
I am not native in English so I do not know what is the actual difference between milling and engraving. Which one is used to produce the PCBs? (BTW, in jewelry?)
What is the main difference in the bits used for each process? Any easy way to recognize them?
I expect to have my MF70 in about two months. A lot to be learnt as far as I can see!
In line with my original post: what should be the minimal set of bits to buy to cater for test, learning (and mistakes).
How would you express how long they last? Minutes of use, length engraved or...?
Yes, I know they are many questions but I am at level zero here.
Gracias.
Old 06-18-2009, 11:53 PM
atferrari,
Milling and engraving can mean the same thing. If there is a diff, engraving is milling by removing relatively little material.
For engraving look for small cutters, say 1/8" or less dia.
As far as circuit board work goes, order up some v-point engraving cutters of your choice, say 60deg point angle, and get some drills in the .025 - .04 range. Dont just get one v-point tool, because you will have an accident (drop it?) and then you will wait for a new tool to come before you can finish your project and that is frustrating.
Andrew Abken
Old 06-19-2009, 12:12 AM
pminmo's Avatar
The very first bit I purchased, a $29 coated precision V bit. Never touched a spindle because I dropped it on concrete while admiring it......tip shattered............ That's before I found Andrews bits, I've been using DrewTronics bits ever sense and never looked back...........
Old 06-19-2009, 12:22 AM
pminmo's Avatar
I just finished a pcb with a Drewtronics bit about an hour ago.
Old 06-19-2009, 09:52 AM
Phil,
Another super nice board! Did you use super glue to hold it down? Looks like you had it dead flat while cutting it.
Andrew Abken
Old 06-19-2009, 10:32 AM
pminmo's Avatar
Thanks, yes, super glue and Drewtronics bits is the only way as far as I'm concerned.........
  #11   Ban this user!
Old 06-19-2009, 01:12 PM
Phil,
Thanks for the good words, I am glad to hear they are working well for you.
atferrari,
Let us know how your board cutting works out for you.
I hope our suggestions help you out.
Andrew Abken
  #12   Ban this user!
Old 06-19-2009, 03:41 PM
atferrari's Avatar
What is super glue?
I told it already, yet at level zero, I need to ask some more questions to people who actually do things. THere is a big difference with forums about electronics: here it seems there is much less blah blah blah. GOOD!
a) "Super glue" is a specific type or just a commercial name? What could be the equivalent in the local (Argentina) market?
b) You bond the board to what?
c) How do you separate it after completing the PCB?
d) Have read of people doing the drilling before milling. Any comments?
My MF70 is closer (maybe in 8 weeks I will have it!
I feel like trying to learn basic rocket science with all this. I hope one day my PCBs would look like the one shown some posts below. Wow!
New to CNC; Buying machine. Thorpydo Benchtop Machines 42 08-26-2008 01:08 PM
Buying a machine ziga General Metalwork Discussion 1 07-10-2008 02:17 AM
help with buying a machine in usa greg b General Electronics Discussion 7 02-14-2008 09:34 AM
Buying CNC Machine in the UK djh82uk General Metalwork Discussion 0 07-25-2007 10:36 AM
Use Machine Shop vs. Buying Machine imp22b General Metalwork Discussion 15 06-06-2007 07:33 AM
