Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PCB milling
PCB milling Discuss PCB milling here.
Old 05-02-2009, 01:55 PM
Konstantin's Avatar
Konstantin is on a distinguished road
Questions about pcb-gcode.
After I run the pcb-gcode script in Eagle and the bottom layer is generated and the drilling is generated I am not sure about this: Do I need to flip the pcb to drill it? Because if I deselect the "Generate top drills" and leave only "Generate bottom drills" there is no output file for drilling. I am confused.
Old 05-02-2009, 02:18 PM
jp_dt is on a distinguished road
That's strange. I just re-checked it here and it works fine. Is there something off with your layout? Maybe just try a board with some vias on it.
I'm using Eagle 5.3.0
Good Luck
CNC mill questions - thrust bearings, leadscrew mounting, general questions tonofsteel DIY-CNC Router Table Machines 8 02-03-2012 04:42 PM
Brass vs Aluminium Vs Steel, questions, questions and questions... alexccmeister General Metal Working Machines 25 08-15-2011 01:40 PM
Newbie- some questions about gerber & gcode michaeljun LinuxCNC (formerly EMC2) 5 10-17-2008 12:42 PM
I have a problem with my gcode or my conversion to gcode , everything is tiny? NickLatech G-Code Programing 0 03-10-2005 01:46 PM
gcode to gcode converter july_favre General CAM Discussion 4 05-24-2004 07:51 PM
