Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PCB milling
PCB milling Discuss PCB milling here.
Old 03-24-2009, 03:54 AM
freejac is on a distinguished road
Need two boards cut
Im working on a new cnc controller and would like to see if someone is interested in milling/cutting a couple for me. Normally I do them the old way of screening and etching, but Id like to see what a milled board looks like.
I could provide the copper clad and cost for your time cutting them. The layout was done in Protel and exported to protel gerber rs274x files. Ill attach a pic file of the board for for clarity. Its double sided and most traces are large enough not to be a problem. Might get tricky at the db25 connector though.
any takers???
Name:	cnc controller board.jpg‎
Last edited by freejac; 03-26-2009 at 03:47 AM. Reason: replace photo of board layout
Old 03-24-2009, 11:16 AM
Gold Member
CJL5585 is on a distinguished road
Copyright
Might want to check the spelling on your board before it is cast in copper traces.
Edit: Just the word Copyright by and name at one time did not constitute a valid copyright. There are certain terms and formats that have to be followed to have a valid copyright, or that was the case a few years ago when I copyrighted some materials.
Nice board.
Old 06-08-2009, 10:51 PM
harryn is on a distinguished road
Here is another place to try.
http://millpcbs.com
Old 06-09-2009, 10:17 AM
Jay C is on a distinguished road
Dimensions? Are you supplying the GCode? # of Holes, what drill sizes? Double-sided? You wanting thru-hole plating ... I think you are better off at a prototyping house.
Old 06-27-2009, 09:14 PM
Zig Zig is offline
Zig is on a distinguished road
Freejac,
I can do it for You but I am in Australia.
If you are interested email the gerbers top and bottom layer, mechanical outline of finished board and excellon drill file.
Unfortunately at this moment I can not do hole plating, my paladium based plating process is in process of being put together but i can use silver ink to make holewalls conductive and plate up copper on top of silver ink.
Does a good one time solder job ( desoldering can cause the copper barell to pop out of the hole) if a heavy handed high wattage soldering iron is used.
I suspect however that a dolop of solder on top and bottom side at the through hole component pin is better.
Surface finish.. silver flash, plain copper or protective solder through lacquer on copper.
Solder mask is a while away.
Open Source Boards Available, Stepper Drivers and Break Out Boards pminmo Open Source Controller Boards 762 11-21-2011 11:51 PM
New Machine Build- What boards are out there smallss General Electronics Discussion 2 01-27-2009 11:18 AM
picstep V4 boards ( looking to buy 4 ) tekno PicStep Controllers 0 04-02-2006 06:51 PM
breakout boards Gads General Electronics Discussion 2 03-05-2006 06:39 PM
help with boards mocnc General Electronics Discussion 15 02-17-2005 09:18 PM
