Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PCB milling
PCB milling Discuss PCB milling here.
Old 03-14-2009, 04:50 PM
hinksj is on a distinguished road
Interested in testing pcb milling software?
I've written a program to be used instead of pcb-gcode.
I've tested it on Mach3 (Inactive mode) but I have not run the resulting gcode on a real machine yet.
I just received my WidgitMaster (Great Machine!!) but I'm about 4 weeks from getting everything completed so I can test it fully myself.
I'm looking for someone that is interest in the added capabilities (over pcb-gcode) to test it and provide feed back.
It run in two stages. Stage one as a ULP on Eagle to acquire raw data.
Stage two is a Windows program that processes the data and produces the gcode.
There are two big differences in this program and pcb-gcode.
#1 - you can use up to three different mill bits to do the routing. Use a Big bit to do most of the work and the smaller ones for cleaning up the tight places.
I download a test board from the Internet and operated on it with two bits. Bit one was .015 with an isolation width of .03 and the second pass using a .005 bit giving a isolation layer of .02. Most of the work with the .005 bit will be air since the .015 did most of the work. The bottom side results are depicted below. Up to three different tools can be specified.
#2 - Optimize the routing path to minimize the number of tool moves. The first example below is the tool path obtained using pcb-gcode. The other one is optimized.
I got the cart in front of the horse on this one .... getting my software developed prior to having a machine to test it on.
If you are interested in testing and providing me feed back - please let me know.
The actual board is 4.0 x 2.0 inches. The pics below are shots from the program and are enlarged for viewing.
Old 03-14-2009, 06:18 PM
acondit's Avatar
acondit is on a distinguished road
The disadvantage of your program is that it won't run on a Mac or Linux, while pcb_gcode will run on both of them plus windows. There is also an optimizer for pcb_gcode.
Alan
http://www.alansmachineworks.com
Old 03-15-2009, 10:50 AM
cwiliam's Avatar
cwiliam is on a distinguished road
I would like to test it hinksj
Old 03-15-2009, 01:54 PM
I decided to start doing my own PCB work without having to make the boards commercially.
I did a lot of reviewing on this site and others about pcb-gcode.
I found people asking about using multiple size bits to preserve the smaller endmill bits and let heaver bits do all the work.
I also looked at the optimization additions to pcb-gcode and thought I could do better.
Since I create software for a living, I decide to create a tool that fit my wants and needs.
I am making it available to any of you that wish to use it.
I feel it provide more flexibility and control over the pcb-gcode options available (there is only so much Eagle lets you do in a ULP program).
I have received a lot from this site and others. --- This is my attempt to give something back.
I wrote a brief tutorial --- you can view it at:
http://joehinkle.com/Eagle2Gcode/Eagle2GCode.htm
If you would like the package ---- This link will download it for you:
http://joehinkle.com/Eagle2Gcode/Eagle2GcodePackage.exe
Old 03-15-2009, 06:37 PM
vladdy's Avatar
vladdy is on a distinguished road
does your software have some sort of 'intelligence, where ,say if you started with the largest bit size, that it would know where material was already removed, and save time by not having to 'remill' already removed excess material..
Old 03-15-2009, 07:18 PM
It starts with what YOU specify as tool 1.
I would make this the largest bit.
Once tool 1 has completed its assign task, Tool 2 is loaded.
For me, this is a .005 endmill.
No, I do not look to see what has already been cut.
It does not take that much time to run the process using tool 2.
These tools have a limited life measured in feet of milling.
My .005 endmill cost $35.
I want to extend the life on it so ... yes it may pass over already cut areas of the PCB, but there are areas that were too small for the larger tool 1 to mill, so tool 2 will now mill them.
This strategy will greatly extend the number of PCBs that can be milled given the tools used.
Old 03-15-2009, 07:44 PM
Greolt is on a distinguished road
Can't get past first base.
Old 03-15-2009, 08:09 PM
In the past, Microsoft allowed developers to package their runtime libraries in with their EXE files.
Since Visual Studio 2005 came out - you have to distribute and install them separately.
I forgot to include Microsoft's redistribution package.
Please download the package again - it is now included.
Run vcredist_x86.exe before attempting to execute Eagle2Gcode.exe.
Old 03-15-2009, 08:55 PM
ULP location is not working.
The concept of using something like a 0.005" endmill for PCB isolation is quite foreign to me. $35
I, like everyone else I know, use a purpose made vee bit to do isolation milling. They last for ages. Very economical.
http://drewtronics.net/spademill.html
Greg
Old 03-15-2009, 09:41 PM
I've update the package to address the issue.
  #11   Ban this user!
Old 03-15-2009, 10:17 PM
Looks like it has a way to go yet.
ID:	77756   Click image for larger version
  #12   Ban this user!
Old 03-15-2009, 11:31 PM
No - that was my mistake.
I am working on have it create the gcode for milling SMD solder mask pads.
That was work in progress that still has issue.
I placed the wrong EXE in the package.
The package has been updated.
Free/Inexpensive Job Pricing Software - Would You Be Interested? thkoutsidthebox Polls 278 09-17-2010 05:54 PM
Newbie Testing/Trial Software Question clevster General CNC (Mill and Lathe) Control Software (NC) 3 11-09-2005 12:13 PM
software for testing drivers/controllers posix Open Source Controller Boards 0 06-09-2005 08:04 AM
Interested? in milling a logo in aluminum for $$$? midevilone Employment Opportunity 1 04-13-2005 01:49 AM
software for testing servos? replicapro General CAM Discussion 11 07-21-2004 04:39 PM
