| PCB milling Discuss PCB milling here. |
| I have a k2 kt 1414 and tried milling some copper clad but the results are not great. One side doesn't cut the same as the other even if the depth is set the same . It seems like the thickness of the board varies from end to end or the something is wrong with my cnc router what can I do? |
| cwiliam Not sure if this is your problem but because isolation routing on PCB material is typically only done a few thou deep it becomes critical that the surface supporting the material is dead flat in relation to the cutting plane. What you can do is mill the surface first then fix the PCB material to that surface. This will ensure that the surface of the PCB is perfectly true to the cutting plane. Hope this helps, Greg |
| I'll try that thank you I was looking at denford webpage and their pcb milling machine .It uses a floating head I was wondering where I can get a floating head for my Cnc Router does Anyone build these or know where I can get one? |
| It's as simple as using a spoil board of MDF. Skim the top flat and you are good to go. I use carpet tape yo hold my PCBs for milling. Depth of cut is .005", just enough to get through the 1oz copper. |
| http://www.ryobitools.com/catalog/sp...ng_bits/AR2070 Came across this has anyone used it? One end is spring loaded you can see a drill bit in the oval hole it has. the bit is held by a hex screw close to the shank thought it could be modified to make spring loaded engraving tool by putting a hex screw flush below the oval hole and reduce tension on the spring |
| You don't need the expense of a floating head. http://millpcbs.com/index.php?option...d=17&Itemid=46 For example see this video done without a floating head:
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
| Results of our 8th CNC BBQ Melbourne May 24 2008 | crocky | Australia, New Zealand Club house | 51 | 06-29-2008 08:09 PM |
| Strange results when zeroing z axis | millbilly | Mach Mill | 5 | 06-29-2007 02:49 AM |
| Mach2 and mach3 have different results. | alexccmeister | Mach Mill | 11 | 04-21-2007 07:36 PM |
| Results from using 8020 for a CNC router | WarrenW | 80/20, TSLOTS and other Aluminum Framing Systems | 0 | 01-05-2006 09:17 PM |
| Poor results, help please! | Swede | Hard and High Speed Machining | 8 | 04-03-2004 11:23 PM |
