Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PCB milling
PCB milling Discuss PCB milling here.
Old 10-30-2008, 11:34 PM
TigerPilot's Avatar
TigerPilot is on a distinguished road
How to make a drill file?
I made in Photo Shop a pcb. I then isolated the lines and the holes and saved them as lines.bmp and holes.bmp. I had no problem converting the lines to a .dxf file using Vextractor but that program can not deal with the small black dots on the white background. I tried another program, WinTopo, and it made small squares from the dots but that is not the problem. The problem is that it doesn't make it in the right scale. I tried PDF2DXF and it has the problem that both other program have. How can I make a drill file from a .bmp or .pdf?
Yoram
Just increased my count by one. :)
NEW pcb drill hole file conversion TO G code NASR1 Mach Mill 0 02-24-2008 11:58 AM
protel pcb Drill file problem with mach2 ? NASR1 Mach Mill 0 06-28-2007 03:22 PM
EaglePCB Drill file TigerPilot G-Code Programing 2 04-27-2005 06:39 PM
Software to make Xsections of an .STL file BK2_SHOOTER Printing, Scanners, Vinyl cutting and Plotters 0 12-21-2004 03:19 PM
how do i make a .cnc file? ljoe1969 TurboCNC 3 01-14-2004 09:56 PM
