Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PCB milling
PCB milling Discuss PCB milling here.
Old 10-15-2008, 10:08 PM
SScnc's Avatar
SScnc is on a distinguished road
Drilling file problem ?
Hi Guys,
I'm getting my X2 setup to also mill PCB's and I'm using Eagle Lite and the pcb-gcode ulp.
I've got my circuit schematic and board done and when I test run it in the Mach3 window (window only now) the traces and pads appear to mill perfectly. But, when I switch to the bd.nc file instead of showing the holes being drilled in the correct locations and pattern they are nothing like the board design and pad locations.
I need some help and advice to get past this step please.
Thanks for any help,
Steve
Old 10-17-2008, 09:13 PM
SScnc's Avatar
Maybe this seismograph pattern is correct after all. But the Z axis never moves on G82 routines.
Has anyone else experienced this problem with G82 with pcb-gcode ?
Or have any ideas at all ?
Old 10-20-2008, 08:57 PM
SScnc's Avatar
Please disregard all that in the previous 2 posts, the pattern is correct and I update pcb-gcode from 3.3.2 to 3.3.3 and everything's working great !
Steve
Syil X3 Drilling Problem wwendorf Dolphin CADCAM 11 10-24-2008 02:16 PM
Peck drilling problem...need help jlembas General Metalwork Discussion 22 10-16-2008 09:11 AM
Need gcode or dxf file for drilling UHU PCB visky UHU Servo Controllers 0 10-07-2008 03:45 PM
Need Help!- Drilling problem.... REVCAM_Bob General Metalwork Discussion 2 05-27-2008 09:18 AM
Drilling Problem with IJK Joe Engel Fadal 12 12-28-2007 01:27 PM
