Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PCB milling
PCB milling Discuss PCB milling here.
Old 07-27-2008, 12:59 AM
Jay C is on a distinguished road
Thumbs up Optimizer for PCB-Gcode Windows GUI
Well, after a day and a half of heads down and a lot of head scratching (C++ and Qt are some very different animals to what I am used to) I am proud to announce Opti_Qt.
[attachment=0]opti_qt.jpg[/attachment]
Not wanting to make it too complex, I opted for a drag and drop interface.
1. Open the Optimizer (double-click opti_qt.exe) note: the two Qt dlls need to be in the same directory or in your path
2. Open an explorer window to your source .nc file directory
3. Ctrl-click (or shift-click) to highlight 1 or more files
4. Click, drag, and drop onto the Optimizer upper pane
5. The files are processed one after the other. The output files are put in the same directory as the input. The output append _OPT tot he filename.
6. Repeat for additional files and directories
Enjoy, and do report issues and kudos
The application file is large due to the embedded DLLs (3.3MB) but it can't be helped.
Click here to see all of the files available for download.
*** If you downloaded (8 of you ) the executable prior to 7/27/2008 your need the MingW10.dll but I recommend getting the all in one file now.
PS: PCB-Gcode is located here: http://www.pcbgcode.org
Old 07-27-2008, 10:54 AM
Guys, I totally neglected to give the original coder (or myself for that matter) proper recognition (any at all) in the windows source code. The only information I have on him at this moment is that his first name is Daniel, he is an Aussie, and he goes by the nick of dakiller. Without his core code, this project would not be where it is today. Thanks Daniel. All future sources will contain this statement or some reflection of it.
Jay
Old 07-27-2008, 05:29 PM
Update: (I know I just can't stop working on this thing) ... there is now a single file (about 3.3MB versus the 5MB beforehand) that no longer requires the DLLs. Ok, now I want some feedback from you guys
Go here for all of the files.
Jay
Old 07-30-2008, 09:59 PM
mcyr is on a distinguished road
JayC,
I can't say I'm doing anything complicated in terms of pcb's but it does work and is very easy to use. Good job!
Best regards,
Mike
Old 07-31-2008, 09:42 AM
Thanks Mike.
Just a word of aution for you and others. It doesn't work for the drill layers (td and bd) Ill need to add additional code to keep all of the drill sections intact ... it may not even be worth it.
Old 08-01-2008, 11:41 PM
Added code to allow for input files with no spacing between G code and coordinate pair.
Not sure how I want to approach the drill files yet so that is not included in this release.
Jay
Old 08-02-2008, 02:33 PM
Cristal is on a distinguished road
Very good job Jay
Old 08-02-2008, 03:41 PM
Thank you.
Old 08-14-2008, 12:18 PM
Update: Some users were experiencing "strange" behavior with the output file format in some programs. The issue was tracked to missing carriage returns. I have fixed this in release 1.1 and uploaded the code to the repository link above. This issue only affected the GUI version.
Jay
Old 08-19-2008, 01:18 PM
ringram2077 is on a distinguished road
Jay
Thanks for the work on this. Works nicely and now works with NCPLOT . One thing I notice however is that it does not seem to optimize a drill file. Should it work for drill files ?
  #11   Ban this user!
Old 08-19-2008, 01:20 PM
Originally Posted by ringram2077 View Post
Jay
See post #5 above. It doesn't work on the drill files. I have not had time to add this. The reason is that the drills are grouped by size and the current code will optimize the drilling, but no accommodate tool changes ... not good.
Jay
  #12   Ban this user!
Old 08-19-2008, 02:48 PM
Ahh yes.....I overlooked that post, sorry. Actually on the boards I make I only use one size drill. I wish I knew how to prevent to tool changes altogether. If no tool changes are called for in the drill file would it then optimize the file ?
Optimizer for PCB-Gcode Jay C PCB milling 26 08-31-2008 02:08 PM
Cutting optimizer kurt5 General CAM Discussion 2 12-07-2007 08:00 AM
New M&G code 3D Viewer, Editor, DNC Dripfeeder and optimizer software! BinaryCam Product Announcements & Manufacturer News 4 05-05-2007 09:56 PM
I have a problem with my gcode or my conversion to gcode , everything is tiny? NickLatech G-Code Programing 0 03-10-2005 01:46 PM
Windows XP or Windows 2000 better with Mach2 Beezer Mach Software (ArtSoft software) 2 10-18-2004 11:08 AM
