Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PCB milling
PCB milling Discuss PCB milling here.
Old 04-17-2008, 04:50 PM
NASR1 is on a distinguished road
Converting protel 99 se to Gcode
hi.
can anyone tell me which one of converter I must use for convert the .txt format of protel 99 se to .Gcode format.I am going to use of mach3 interfacing for my cnc machine.
Thanks.
Old 08-21-2008, 06:45 AM
HARI_R is on a distinguished road
try CopperCAM its demo version
"www.galaad.net/coppercam-eng.html"
Old 09-04-2008, 04:03 AM
Images
ID:	65919   Click image for larger version
ID:	65920   Click image for larger version
Old 03-30-2010, 01:45 AM
Wardend52 is on a distinguished road
PCB Manufacture rom Protel99SE
Hi NASR1,
I make pcb on my mill using Protel99SE. I export top and bottom layer cam files in Gerber format, then import into CopperCam, which exports Gcode for use in Mach3. In CopperCam you can select pads and set hole sizes etc... CopperCam is worth the purchase.
Regards,
Old 05-23-2010, 12:35 PM
lrm72 is on a distinguished road
Originally Posted by NASR1 View Post
hi.
Thanks.
try "PhCNC LS" - really professional software!
Old 05-23-2010, 11:35 PM
Zig Zig is offline
Zig is on a distinguished road
How much is the phCNC LS software and what kind of outputs does it generate?
Old 05-25-2010, 12:57 PM
PhCNC LS generates G-code. You can find comparison between CopperCam (recommended to you above) and PhCNC Ls on this page: http://www.accuratecnc.com/software_tests.html. There, you will find also useful links for demo or trial versions of these and other software. You can test yourself and see which one matches best your need. Regarding the price, I have no idea, because we bought PhCNC together with a machine. Check on the site or contact Accuratecnc.
Protel is driving me crazy ez-cnc.com General Electronics Discussion 3 03-30-2010 01:54 AM
Need Help!- How I can get excellon file (.NC) from Protel? xdev Kellyware CAM 0 03-08-2008 09:02 PM
protel pcb Drill file problem with mach2 ? NASR1 Mach Mill 0 06-28-2007 03:22 PM
I have a problem with my gcode or my conversion to gcode , everything is tiny? NickLatech G-Code Programing 0 03-10-2005 01:46 PM
Dumb Protel Question RXTurbo General Electronics Discussion 3 07-29-2004 06:58 AM
