This isn't DXF, it's g-code, might help?
http://groups.yahoo.com/group/pcb-gcode
Hi Guys
Ive not had too much luck with making pcb's, I either can't get the board flat or can't find the right bit.
Im working on a spring loaded engraving tool, but it's taking a while.
In the meantime I would like to use the mill with an etch resist pen, but how do I export the board from eagle to dxf, and how to I convert that dxf into gcode, so it basically draws where the tracks should be (and fills them in).
Any Thoughts?
DJH
Free DXF Files - myDXF.blogspot.com
Hiya
Thats what ive been using, but I have been having problems getting the boards flat enough, I want to try it with an etching pen int he spindle, pcb-gcode removes the copper around the tracks, i need the pen to effectivley colour in the tracks
Thanks anyhow tho
DJH
I did this with Vcarve Pro, just to see If it would work.
The holes are all the way thru. (1 side board).
