Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PCB milling
PCB milling Discuss PCB milling here.
Old 03-25-2008, 12:25 PM
reiyuki is on a distinguished road
PCB Milling bits
Quick question. I'm getting ready to make some PCB's using a CNC Taig and was wondering if anyone has experience with anything other than a half or quarter engraver bit.
I see these things at the hardware stores all the time, and was wondering if it would be good for PCB. I'm guessing it won't work due to the shape of the tip, but who knows?
http://www.dremel.com/en-us/attachme...=66240&I=66309
Old 03-25-2008, 12:29 PM
samco is on a distinguished road
I have had really good luck with http://www.thinktink.com/stack/volum...e/mechmill.htm
around .007 isolations
sam
Old 03-25-2008, 04:04 PM
I saw those a while back, will order some when I get a chance.
Any preference for degree? 30/45/60
My spindle can do 10,500rpm , what would be a reasonable ballpark feedrate to match?
Old 03-25-2008, 04:06 PM
jcoats's Avatar
jcoats is on a distinguished road
http://drillbitcity.com/ -- resharpened bits a very good prices, IMHO.
Old 03-27-2008, 09:59 PM
blackbeard52 is on a distinguished road
bits
Try your dentist.... he will have burrs and cutters made of carbide that he or she will donate for the cause. Most are used once and thrown away. if you can get a holder it is a never ending supply of mini engraving and cutting tools.
Bob
Old 03-28-2008, 11:58 AM
pminmo's Avatar
pminmo is on a distinguished road
http://www.millpcbs.com/index.php?page=links Drewtronics bits for the price are pretty awsome. Feed rates depend on cutter size, spindle rpms, material removal and remaining material. At 25K rpm and 9mils of material removal, clean edges with a new sharp bit can be had at 12ipm. If the remaining trace width is wide enough you can go faster, as remaining trace width gets smaller you run the risk of tearing the remaining trace. For example if your leaving a 10 mil trace, you are taking chances at faster than 8ipm for the above example.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 09-14-2008, 01:31 PM
dang's Avatar
dang is on a distinguished road
That's still not a good enough reason for me to go to the Dentist.
Frustrated: Breaking bits milling Aluminum fivefishcnc General Metal Working Machines 35 07-19-2009 07:38 AM
milling bits pike88 WoodWorking 4 09-24-2007 01:02 PM
Luv those little bits.. CRFultz DIY-CNC Router Table Machines 27 05-14-2005 06:41 AM
Milling bits for CNC mill.... studysession General Metal Working Machines 9 01-21-2005 03:32 PM
Where to buy CHEAP PCB milling bits abasir General Electronics Discussion 12 04-17-2004 10:14 PM
