Results 1 to 4 of 4
Thread: need help with eagle to pcbgcode output
    Oct 2011
    Hello, I am hoping some folks here use a work flow with Eagle - Pcbgcode and could shine some light on my problem.
    I'm new. I have studied pcbgcode and still can't get it right. Less than 10% of traces are output. Also it shows tool path for milling the board outline, I have the top etch as a ground plane, maybe it is cutting my ground plane, lol.
    I am in no way blaming softwares, I am sure i didn't check a box somewhere.
    eagle pic is what it should look like.
    cambam pic is what I get.
    Anyways, if someone has a minute please download the board file and see what pcbgcode outputs for you, or take a look at the pictures to see if maybe you recognize the problem.
    NOTE: Rename brd file.dxf to: brd file.brd This is an upload work-around, since the Eagle .brd file extension is an invalid type.
    Eagle 6.1
    pcbgcode 3.5.2.11
    cambam 0.9 for viewing paths and editing
    Mach3
    all traces on board are 10mil, clearance 8mil
    my setup for pcbgcode is:
    default .001
    max .008
    step size .005
    tool size .007
    Attached Thumbnails Attached Thumbnails need help with eagle to pcbgcode output-cambam.jpg
    Attached Files Attached Files
    Dec 2004
    Memphis, TN
    PCB-GCODE Setup General Options
    Explains the PCB-Gcode configurations.
    -Jay
    Oct 2011
    thank you Jay C,
    I have seen your name all over the internet and I hope you continue for the sake of others like me who have wondered just how far they can hurl their laptop.
    The link you gave is one of the most practical I have seen. I had success in less than 3 minutes after clicking it. Let it be a guide for others...
    BTW: here is what worked
    default .0001
    max .0001
    step size .006
    cheers
    Attached Thumbnails Attached Thumbnails need help with eagle to pcbgcode output-fixed_now.jpg
    Dec 2004
    Memphis, TN
    You are welcome. Phil's site is what helped me get up to speed with PCB-Gcode and double-sided milling.
  1. Eagle KV 750
    By fastleather in forum Classifieds Help!
    Last Post: 02-17-2011, 09:46 AM
  2. Fun Eagle
    By drawbar in forum WoodWorking
    Last Post: 01-23-2011, 02:05 AM
  3. Need Help -> Eagle and PCB-Gcode
    By keebler303 in forum PCB milling
    Last Post: 01-16-2009, 01:18 PM
  4. Eagle CAM Processor output - Mach3 Size issue
    By deleteallusers in forum G-Code Programing
    Last Post: 05-02-2007, 10:14 AM
  5. Eagle CAD
    By jhwatts in forum General CAM Discussion
    Last Post: 01-26-2006, 05:41 PM
