Results 1 to 3 of 3
Thread: Any health hazards in milliing standard glass fiber PCBs?
    Oct 2011
    C
    Other than the standard issues with machining plastics/epoxy such as the volatile organnic fumes/plasticizers that you can breath in, are there health hazards with the glass fibers? E.g. the dust generated containing fine fibers etc. The fibers arnt asbestos but is it normally a problem with milling PCBs especially when you dont know what the epoxy really is that is used in the PCBs?
    Jul 2005
    If you were doing it eight hours a day five days a week without an system to control the dust or without a filter mask you will probably experience problems.
    Brief exposure machining a few boards is not particularly hazardous but it is a good idea to use a good filter mask and keep the area well ventilated.
    Sep 2011
    I would install a vacuum that exhaust to outside.
    I think breathing in glass dust can lead to Silicosis,
    I would think the levels are different for everybody.
    A little for you may be way to much for me.
    Personally, I would not risk it.
    I also intend to make PC Boards and intend
    to vent my vacuum to outside to be safe
  1. is machining/cnc bad for your health?
    By roadtrip in forum Safety Zone
    Last Post: 02-24-2011, 12:24 PM
  2. Hazards of 360 brass?
    By ewest in forum General Metalwork Discussion
    Last Post: 11-23-2009, 02:14 PM
  3. Mounting rails on glass - how flat is glass?
    By Swiss in forum Linear and Rotary Motion
    Last Post: 07-25-2008, 03:10 AM
  4. Tungsten Grinding ( Hazards? Safe practices?)
    By Rich05 in forum Welding, Brazing, Soldering, Sealing
    Last Post: 01-19-2008, 11:52 PM
  5. Chalcogenide Glass Health Issues
    By ImanCarrot in forum Safety Zone
    Last Post: 11-10-2005, 08:30 AM
