Results 1 to 3 of 3
Thread: PCB Milling for Fanuc
    Mar 2008
    Hello,
    I have been designing my PCB board in solidworks the hard way (drawing shapes) and would like to move to an actual PCB design software.
    I use the Fanuc post processor in SolidCam to generate my Gcode normally.
    What software should I use?
    It would be nice to import the PCB design into SolidCam for optimizing toolpaths... but not necessary.
    Thanks,
    J
    Mar 2008
    ECHO echo ,,,, ....
    Really quiet in here
    Sep 2006
    romania
    Cadsoft Eagle could help you to draw a correct schematics, create a board according to the schematic, and export a g-code file from your board.
    In Eagle, plugins are called "ulp"s, are in c-like language and access the sch/brd database.
    After you draw the schematic, you open the board (leaving sch opened !!!!), position components on desired places and route the airwires. After that, use "pcb-gcode.ulp" or "gcode1.ulp" to create the g-code.
    Both pcb-gcode and gcode1 are available on the Download/ulp area on the Cadsoft webpage. Google can help you more
    Free version of Eagle allow a pcb of 8x10cm, with 2 layers, but "medicine" can be found on the internet.
  1. CNC Milling with a Fanuc Robot
    By MBX5 in forum General Metalwork Discussion
    Last Post: 11-25-2010, 11:49 AM
  2. Need Help!- Denford Fanuc Milling M/c
    By erics in forum General Metalwork Discussion
    Last Post: 07-01-2009, 07:15 AM
  3. VA-50 CNC MILLING MACHINE FANUC 10 M
    By A.Ramli in forum Test Forum
    Last Post: 04-27-2009, 03:35 AM
  4. VA-50 CNC MILLING MACHINE FANUC 10 M
    Last Post: 03-24-2009, 05:42 AM
  5. fanuc om c 3d milling
    By manueldiasm in forum Fanuc
    Last Post: 05-23-2008, 02:05 PM
