Results 1 to 3 of 3
Thread: What depth to use for milling?
    Nov 2010
    Cyprus
    Hi guys. Newbie here
    I ordered some 30 and 60 degree cutters and waiting for them. My question:
    Let's say I want to create 10 mils lines. How do I know the required depth for my Z axis?
    As I understand it, since we are cutting isolation lines, the 10 mils line depends on the diameter of the tool which how ever (since it is a V cutter) depends on the depth at the time of cutting.
    I would appreciate any information.
    Thanks!
    Jan 2008
    Turkey
    You can use PhCNC Demo (Insulate tool) for depth calculations. But you need to know the tool tip !
    Nov 2010
    Cyprus
    Thanks for that. I will take a look.
  1. Need Help!- Milling Feeds Speeds Depth and all that rot Newbie
    By AndrewEvans in forum Bridgeport and Hardinge Mills
    Last Post: 02-16-2011, 10:43 AM
  2. What is needed for milling Aluminium (40mm depth)
    By Helloagain in forum General Metal Working Machines
    Last Post: 03-24-2010, 02:29 PM
  3. Need Help!- Incremental depth milling for 3D toolpath? (V21)
    By speedofsound in forum BobCad-Cam
    Last Post: 10-17-2008, 11:15 PM
  4. Maximum CNC milling depth
    By Dr. DRE in forum General Metalwork Discussion
    Last Post: 12-16-2006, 11:39 PM
  5. Milling: low depth passes or all the width?
    By PEU in forum DIY CNC Router Table Machines
    Last Post: 11-02-2005, 06:57 PM
